Another build thread
Old Feb 6, 2020 | 07:00 PM
  #91
7.3 forever's Avatar
7.3 forever
I checked carrier bearing when I removed the spacer I had installed in it for lift and was good as new or atleast seemed that way to me.
Old Feb 9, 2020 | 09:21 PM
  #92
7.3 forever
Well dug threw my stash of shafts and did some ruff measuring by myself. It looks like possibly a set of shafts out of a 2005-2007 F250’s crew cab short bed auto 6.0 truck. Might possibly work I’m not dead sure yet but ruff measurements show they may drop right in once I order a the 1410 flange with a 2in pilot for my tcase. I’m planning on ordering the flange this week if they work I definitely plan on replacing the ujoints and carrier bearing and having them balanced.
Old Feb 14, 2020 | 08:21 PM
  #93
7.3 forever
Also on another note picked up a new engine harness from riffraff.
Old Feb 14, 2020 | 11:23 PM
  #94
nateairman's Avatar
nateairman
Now that would be nice to have!
Old Feb 15, 2020 | 08:12 AM
  #95
BBslider001's Avatar
BBslider001
I know of a couple of guys that have done these recently. It made a world of difference in how their truck ran. Let us know how it goes!
Old Feb 15, 2020 | 04:25 PM
  #96
7.3 forever
Definitely will I don’t plan on installing on my current engine though so it’ll be a little bit. But on another note 2005 6.0 crew cab short bed 4x4 drive shafts. Will work in my extended cab 96 with bigger tcase by buying 1410 flange with smaller centering hole and the Superduty flange for rear axle. I test fit them this weekend plan on ordering correct flange and all new spicer ujoints. ASAP plan is to have them balanced before installing them.
Old Feb 22, 2020 | 10:18 PM
  #97
7.3 forever
Well have the replacement engine on stand half to pull hpop off to send to be made into a t500 and then get rest of parts ordered in next couple of weeks.
And it looks dirty as can be more rusty really than anything. But I’ll post pics tomorrow of the frame it’s horrible.
Old Feb 22, 2020 | 10:43 PM
  #98
BBslider001
What are your plans with this engine?
Old Feb 22, 2020 | 11:42 PM
  #99
7.3 forever
Headstuds
valve springs
pushrods
new engine Harrness
t500
all new oem sensors
oem valve cover gaskets
stock turbo with billet wheel
150 cc stock nozzles
melling low pressure oil pump
efuel
future plans are to swap in 250/100 and a s369sxe
Old Feb 22, 2020 | 11:43 PM
  #100
7.3 forever
Eventually would like to be atleast close to 500 rwhp if possible.
Old Feb 23, 2020 | 06:18 AM
  #101
PSU4ME's Avatar
PSU4ME
That’s great! Ours went from looking like that to looking like this:
Good luck. Sounds like a great list of upgrades. You putting a 360 bearing in the turbo?
Old Feb 23, 2020 | 11:09 AM
  #102
z31freakify's Avatar
z31freakify
Did you ever go with the 99+ timing cover? You could do the the stock E fuel from the SD, its worth it and you save $$ if you have the stuff laying aroumd.
Old Feb 23, 2020 | 09:40 PM
  #103
7.3 forever
All ready have efuel but I really like the mark Fugazzotto topside of his kit so probably gonna order it. Most likely is the plan at this time I’ll keep you guys posted on progress.
Old Feb 24, 2020 | 09:53 AM
  #104
Hit Man X's Avatar
Hit Man X
Thumbs up
Pop on a Fluidampr if you can swing it. Rojo runs quite a bit better with it.
Old Feb 24, 2020 | 02:34 PM
  #105
7.3 forever
Actually I plan on doing a fluiddamper and diesel site water pump and hoses if there’s enough in budget.
