Well exactly like the title ses for couple years now I’ve done bunches of small threads but I’ve decided to start a thread to combind everything. Probably won’t involve big crazy mods for time being. I’ve fallen behind on maintenance recently but trying to catch up slowly now. Now for details on truck it’s a 96 F250 extended cab long bed 4x4 auto. Had 177,000 on it when I purchased it in 2013.
current mods
05 axle swap 3:73 gears
35/12.50/20 planning on dropping down to 33s
Gauges egt, Trans , boost
sd trans lines 6.0 cooler
4in exhaust
rebuilt freakify mod turbo billet wheel
baby swamp injectors
Intake
diy Efuel with stock sd pump and sump
diy extra large rear diff cover
hydroboost and fsuperduty master cylinder
ebpv delete
diy pedestal gut
Recently new or new parts
injector cups 5000 miles ago
had to replace passenger head due injector cups broke off used head
donut gaskets 10,000 miles ago
motorcraft thermostat 5000 miles ago
injector orings while injectors where out for cups
all new rear ujoints replaced with spicer
new passengers radius arm bushings
trac bar balljoint
steering drag link
year old alternator
new ac lines
oil cooler seals
newer eBay headlights
recently swapped e4od back in after a zf swap aftermarket converter hd tugger kit
sd trans pan
newer door gaskets and window felts
ipr
hydra canned tunes waiting to get different tires and few other things done
new shocks
newer valve cover gaskets
newer motorcraft glow plugs
things waiting to be installed
everthing to update efuel to an fittings and Walbro pump
6.0 intercooler and e99 Spyder and stock steel sd pipes
one upper balljoint I know only one but only one that’s bad
New brake light switch
used shift lever indicator
F350 front shaft and yoke just half to find conversion joint
Need to finish bracket for 03 center console
need to get new neutral safety switch
need to reseal plenums have sealant already
05 steering box waiting to get time to install
future plans for truck
s369 sxe diy mount
t500
valve springs
head studs
push rods
160/100 or possibly 238/100
4link kit for frontend
new paint job
A lot of the big stuff is gonna take some time but the smaller stuff I will slowly be working on.
New updated list. As of 10/22/19csd t4 with s369sxe rosewood 250/100t500 head studs riffraff plenums melling lpop fluid balancer either comp cam 910 or beehive Moroso pan gasket motorcraft dipstick adapter and Sd dipstick Oem valve cover gaskets possibly Sd style motorcraft glow plugs new rail plugs pushrods
Pics from over the years body is getting differ due to some neglect age and fact that for two years I used to cut and haul fire wood. And work out of and it’s still my dd at moment. Any advice or input is welcome.
Wheels really aren’t my style but needed different ones for axle swap and picked them up dirt cheap so hopefully that’s something else for list to in future.
Thanks guys yes it’s nice to have a shop to work for sure the pics of installing axles wasn’t in my shop didn’t have a 2post at that time. Plan for the weekend is to install the one upper balljoint I got which is a moog balljoint. For now I’m just gonna replace the one that’s bad but in a year or so I plan on rebuilding entire frontend with spicer or oem parts. also hopefully I’ll get to finish redoing my fuel system.
Here’s everything for fuel system upgrade number2 an fittings and lines new cat post filter I’d like to run cat pre filter but price difference is insane on those atleast I think.
Yes and no on that it’s definitely better but until I swap in the 05 steering box I won’t get the full capability of the axles available turning radius.
Sorry guys just been busy at work haven’t had time to work on truck much really wish I had a spare rig need to be getting bunch of maintenance done. On a side note I’m keeping a motor out of one of my part out trucks for a spare for mine was a really well running truck motor is supposed to have around 170,000 miles I’m gonna run a compression test before pulling it rest the way out of the truck. If compression numbers are really good then I’m going to swap it over to a 99 up cover and associated parts and slowly start building it to drop in.
I know it’s been a while don’t have much of a update but I did pickup a used good 17 hpop. Got the parts truck with my spare engine in far bay of my shop getting ready to scrap what’s left of that parts truck. On another note I’m probably going to be getting this engine ready to go in my truck over the next month or two. My current engine has little more blowby than I prefer and has several oil leaks and things that I wanna get taken care of. I’ll try to get some pics here soon.
Well been a while guys for the time being work has been busy. Anyway Monday one of my trans lines came lose. Luckily I caught it before it dumped much out only lost about 2quarts. Anyway think this weekend I’m gonna pull it in and attempt to reseal the drivers side intake plenum again.
Okay guys got my spare motor pulled out of parts truck this week. And I know has K&n type filter on it I put that on there because stock filter was filthy. Anyway plan to swap timing cover over to 99up setup what gaskets would you recommend I’m planning on a Moroso oil pan gasket. But I’ve not been able to find a complete motorcraft gasket set I’ve used Felpro in the past. But I’m wanting to do this once and be done or atleast done until I can afford to build a new engine. Anyway here’s list of stuff I plan on ordering here soon if money allows
910 valve springs
dipstick adapter
valve seals
timing cover gasket set brand unsure
List of stuff is much larger but that’s what I think I’ll be able to afford to atleast get the project started here soon hopefully. Here’s full list as of now but definitely gonna take a while.
910 valve springs
valve seals
glow plugs motorcraft
oil cooler seals oem
moroso oil pan gasket
dipstick flange
reseal used 17 hpop I bought
new oem icp
new oem ipr
build diy t4 Mount
3in intake plenums
s369 sxe
sd valve cover harness
headstuds
as for injectors I’m really thinking of going to 238/100 but may just go to stage 2s and be done but I’ve not decided
melling lpop
Anyway this build is probably gonna to take several months but any advice or input is welcome.
Also trans i in’s I have now seems to do great but I do have a spare fairly recently rebuilt Trans I picked up in a parts truck recently. I know not a built trans and hopefully that’s in the future but I think as I drive with common sense I’ll be fine.
