Another build thread
Old May 2, 2021 | 08:03 AM
  #241
BBslider001's Avatar
BBslider001
Originally Posted by Khan
This is what the Strictly Diesel set up looks like. With the actual alternator bracket or AC bracket the sensor runs parallel with the bottom of the bracket, and looks very clean.
I am dumb. I have one of those in a box waiting to go on. I'd highly recommend it @7.3 forever
Old May 2, 2021 | 09:08 AM
  #242
7.3 forever's Avatar
7.3 forever
I definitely like the fact that it’s not in front of the hpop cover anymore. But as of now for budget reasons I’m gonna half to stick to what I have l. But definitely a lot slicker setup.
Old May 2, 2021 | 10:32 AM
  #243
TheFecalFanatic's Avatar
TheFecalFanatic
You know nothing @BBslider001
Old May 2, 2021 | 10:33 AM
  #244
BBslider001
Agreed...not even sure why I am on a truck forum
Old May 2, 2021 | 11:45 AM
  #245
oldbird1965's Avatar
oldbird1965
I know why, to help dummies like me!
Old May 3, 2021 | 07:30 AM
  #246
BBslider001
Ha! Thanks Glenn. Just one dummy helping another.
Old May 3, 2021 | 05:17 PM
  #247
7.3 forever
Just ordered a 5in exhaust as well currently truck still has factory downpipe and a 4in homemade exhaust. So figured why not.
Old May 6, 2021 | 05:59 PM
  #248
7.3 forever
Well my injectors made it to rosewood Monday afternoon. Said there about 3weeks out before they will get to tare into them. Hopefully this weekend I’ll be able to get manifolds and motor mounts on and maybe get my accessories brackets powder coated as well.
Old May 6, 2021 | 06:02 PM
  #249
TheFecalFanatic
Jim will get you taken care of no doubt! Bet you're excited to get this thing back together. Are you going to do the dual tensioner TSB as well?
Old May 6, 2021 | 07:44 PM
  #250
7.3 forever
Yep already have the belt and tensioner from Riffraff.
Old May 6, 2021 | 07:49 PM
  #251
7.3 forever
And yes I’m definitely ready to get the engine in my current engine runs okay as it is I have modified stock turbo and 150cc injectors and canned hydra tunes. I’m pretty sure my current engines hpop is definitely weak as light comes on easy and to be honest truck feels like it has more power. If you only use the first 2/3 of the pedal really falls on its face if you run wide open throttle. Need to do some data logging before I pull engine plan to put in another cab and chassis truck I have.
Old May 9, 2021 | 08:22 PM
  #252
7.3 forever
Well no pics sorry guys but I got my manifolds cleaned up and header paint on them and cured them in the oven. Installed with gaskets and new bolts along with I cleaned and painted my motor mounts and reinstalled them. And I installed the sd dipstick tube pretty much to point now where I’m waiting on parts.
Old May 10, 2021 | 08:09 AM
  #253
BBslider001
Would like to see photos of the manifold install if you can. Not many of those photos lying around here.
Old May 10, 2021 | 07:34 PM
  #254
7.3 forever
Will this weekend I just cleaned up the originals and used header ceramic paint on them. Cured them in oven and installed with new bolts and I did use gaskets.
Old May 10, 2021 | 07:47 PM
  #255
Edgethis's Avatar
Edgethis
Was it the ceramic prime and paint setup that cures at like 600*?
I did that on my turbo pedestal and turbine when it was put. Turned out great and still looks good.
