Well, it would be fun to plow around busco in the excursion.
But...I do have a dirt bike that I take out there. I quit going because of the crowds.I did end up going a few months ago with some friends and tore up my stuff real good out there. Busted the rear shock, busted the fork seals, buried it up the engine in the swamp, hit the mx track and caught some sweet air.
Me and a buddy spent some time poking around the wiring for my passenger side window motor. About a hour with a test light and multimeter. I ended up having to run a new line from the driver side to passenger side. I now can control the passenger window from the driver side, but still no luck with the passenger side control. Oh well, the driver side is the important one anyways.
I also started putting red/white strobe lights in the grille. I had to extend the wiring harness, I got 3 of 6 of the pods wired in. So 27 of the 54 LED lights work right now.... lol
Thanks, just ordered me a set of 285/70/17s to replace the nearly worn out 265s that are on it. It'll probably still be a couple weeks before I have them installed. Once they're on though, it should give it a slightly meaner look.
