Official NCFTE Works Thread
Old Feb 4, 2017 | 09:48 AM
  #646
77mud's Avatar
77mud
The noise is definitely coming from the top end.
Old Feb 4, 2017 | 09:54 AM
  #647
Benztechnc's Avatar
Benztechnc
At this point I'd probably pull the valve cover off and check all the rockers and springs. Have you been able to narrow it down to a specific cylinder?
Old Feb 4, 2017 | 10:25 AM
  #648
77mud's Avatar
77mud
Cylinder 1 misfire, and that sounds like where the tap is coming from. However even though the compression test seemed good on it, I'm pretty sure it's either got a blown head gasket, or a Crack in the head. If you take the cap off the coolant reservoir and crank the truck it non stop bubbles air out.
Old Feb 4, 2017 | 12:05 PM
  #649
Benztechnc's Avatar
Benztechnc
Well if it's leaking combustion gas into the coolant, then I'd start there. Pressure test the coolant system, just borrow a tester from the auto parts store. Pump it up and see how long it holds for. Should at least hold for 5 minutes. If it doesn't and you don't see any coolant then pull the plug and have someone crank it over, see if it sprays any coolant out of the cylinder.
Just another idea.
Old Feb 4, 2017 | 03:22 PM
  #650
ubereal2's Avatar
ubereal2
Yup, at the minimum a head gasket. If it's worse than that, it would be easy to walk away from the truck. When we replaced my 01 F150, it was at 200K and had been a great truck. But it was needing a couple of grand put into it to be dependable, and it was only worth that much. So in debt we went.
Old Feb 4, 2017 | 03:38 PM
  #651
77mud's Avatar
77mud
Yea not sure what I'm going to do right now. I had big plans for the day, but I've managed to not do anything.
Old Feb 4, 2017 | 03:40 PM
  #652
ubereal2's Avatar
ubereal2
I didn't really have much for plans today, other than possibly go through what can get packed for the move. Mostly, I just kept the sofa weighted down...
Old Feb 4, 2017 | 03:41 PM
  #653
ubereal2's Avatar
ubereal2
Originally Posted by Benztechnc
I also got one of those coupons for the Harbor Freight grinder that I'd like to go collect. I'll see how the master cylinder goes first though. May treat myself to a bench vise too while I'm out.
You'd better get 3, so when each one quits, you have another one to use. Then you can take all 3 back at the same time.
Buy a good tool. At least a Craftsman, and you'll get to use it a lot longer.
Old Feb 5, 2017 | 06:23 AM
  #654
77mud's Avatar
77mud
Same here.
Old Feb 5, 2017 | 06:24 AM
  #655
77mud's Avatar
77mud
Dad has one of there grinders, it's a little under powered compared to my dewalt, but works well. I've had there electric impact for 3 years, dad finally had to replace his after 10+ years.
Old Feb 5, 2017 | 06:29 AM
  #656
77mud's Avatar
77mud
Just another idea.
I got to thinking.... I have a heater line that seeps so I'm not sure if a pressure test would work or not. I'll give it a try though. The only thing that doesn't make since is I have no water in the oil at all.
I'm thinking about renting a inspection camera from Autozone and look down in the cylinder now that it's been setting for a week and see if I see any coolant I'm the cylinder.
Don't they also make a test to check for combustion gas in your coolant?
Old Feb 5, 2017 | 07:00 AM
  #657
ubereal2's Avatar
ubereal2
I had one of their electric grinders that self destroyed when I plugged it in and used it that first time. An electric impact, that didn't impact, a drill that caught on fire, a heat gun that got so hot, it too caught on fire.
There isn't always a mix of oil and coolant. That happens when the bad gasket, or crack in the head happen between a water and oil passage, then they mix.
Old Feb 5, 2017 | 08:27 AM
  #658
77mud's Avatar
77mud
I figured if enough was making it in the cylinder, it would end up in the oil aswell.
Old Feb 5, 2017 | 08:40 AM
  #659
ubereal2's Avatar
ubereal2
And it could, it just has to get past the piston and rings. Are you getting any whits smoke out of the tail pipe?
There are test kits that you can get to measure exhaust gasses in coolant.
Old Feb 5, 2017 | 08:41 AM
  #660
dlibson's Avatar
dlibson
Burns out the tailpipe then.
