Official NCFTE Works Thread
Old Jan 13, 2017 | 08:30 AM
  #616
77mud's Avatar
77mud
Glad your dad made it out alright, a rollover is no joke, I still randomly see my rollover in slow motion when I close my eyes.
Old Jan 13, 2017 | 08:32 AM
  #617
77mud's Avatar
77mud
Well this weekend I'm planning on taking the wife's car to a local shop to get the new tires installed to replace the worn out Federals on it.
I also plan on trying to get the rear drum off the old Dually and seeing what I need to fix the brakes.
Old Jan 13, 2017 | 10:24 AM
  #618
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
For a budget tire we've been getting good mileage and wear from nexxens. It's a korean tire brand but we've got two korean cars as well.
I have goodyear's on the excursion.
Old Jan 13, 2017 | 11:58 AM
  #619
77mud's Avatar
77mud
I've already got the tires, I ordered them from Tire rack. It's getting a set of Generals Altimax tires. I did research, and read reviews for 3 or 4 days before making the decision.
Old Jan 13, 2017 | 03:17 PM
  #620
77mud's Avatar
77mud
Well I got the dually pulled apart today, a full turn backing off the brake adjuster and it freed right up, took the drum off and checked it out. Apparently it had been to tight for awhile (had a shop check them last time I had tires put on the rear), but everything looked intact. I got it set right guess I'll take it for a spin sometime and see how it works out.
Old Jan 13, 2017 | 04:58 PM
  #621
FordxFour's Avatar
FordxFour
Dusty, glad you dad is OK. We never know what may be awaiting us in our travels.
Old Jan 13, 2017 | 11:03 PM
  #622
FordTruckfan89's Avatar
FordTruckfan89
Thank you. He's bent on fixing that excursion, so we'll see what happens. Took spinning it over three times to get the air out of the fuel lines, but it fired up and ran smooth.
Old Jan 16, 2017 | 06:07 AM
  #623
Cracker289's Avatar
Cracker289
Dusty, I'd be amazed if he can fix it after that much body damage!
77Mud, I have General Altimax tires on my car and I love them.
Old Jan 16, 2017 | 06:27 AM
  #624
FordTruckfan89
It'll be getting a body swap if he does fix it himself. Trying to find a clean gas 2wd one or diesel one that needs an engine for cheap.
Old Jan 16, 2017 | 11:58 AM
  #625
77mud's Avatar
77mud
So far so good on those tires, 100x quieter than those Federals that were on it.
Old Jan 26, 2017 | 03:18 PM
  #626
77mud's Avatar
77mud
My 97 F150 through a CEL Tuesday night P0301 so I picked up a new plug because it's cheap and simple, but that didn't do anything. Spark plug wires are about 3 months old, I also swapped injectors between 1 and 2, and missfire stayed with cylinder 1. It also gained a tap when the missfire started but only above idle, but it doesn't sound like a rod knock. I also knoticed if you unplug injector 1at idle it taps/knocks 3 or 4 times, however if you unplug any of the others it doesn't do that. I checked and I definitely have good spark from the plug. I plan on picking up a new compression tester tomorrow since mine never was returned. If you take the oil fill cap off it doesn't have any blow by at idle, however if you rev it you get a quick cloud out of it.
Any other ideas? I thought about picking up a kit to check the injector pulse.
Old Jan 26, 2017 | 06:05 PM
  #627
dlibson's Avatar
dlibson
Just too make sure, #1 is the passenger side front hole. I would suggest swapping wires to see if it follows a wire, too.
Old Jan 26, 2017 | 07:00 PM
  #628
77mud's Avatar
77mud
Yes passenger side front hole. Like I said, the spark will arc over a inch.... bad thing about the 4.6 wires is the way they run its harder to find one to just swap.
Old Jan 26, 2017 | 07:07 PM
  #629
ubereal2's Avatar
ubereal2
Along with a compression tester, another good tool to have is a vacuum gauge. It can tell you a lot that the compression tester won't. And like you mentioned needing to test the pulse of the injector, you need a Noid light. I have a set here, but that doesn't do you much good.
Let us know what you come up with.
Old Jan 26, 2017 | 08:32 PM
  #630
dlibson's Avatar
dlibson
Just checking, I caught someone fighting a miss for quite some time cause of that before. I know the wires suck with the routing. Even a good arcing spark can be too cold. Where are you located?
