1986 F-250 Progress Thread
Old May 10, 2013 | 10:18 PM
  #436
FordFETruck's Avatar
FordFETruck
Yeah, mine has one tiny spot of surface rust under it. But it's nothing bad. I took my valve body out, made lots of red rain. So far so good, I'll post pictures in a bit.
Old May 10, 2013 | 10:38 PM
  #437
GruesomeJeans's Avatar
GruesomeJeans
Hey Matt, which car show are you going to this year? I'm planning to take both my bronco and my beetle to Ed Britz's show up at Coastal. The plan is to have the same friend who went last year, drive the bronco while I take the beetle. I'm a little nervous cause I don't even like my family to drive the bronco, much less my friends. Since it's only down the road I figure I'll teach him how to handle it, then he should be fine.
Old May 10, 2013 | 10:39 PM
  #438
FordFETruck
Are they both on the same day?
Old May 10, 2013 | 10:43 PM
  #439
FordFETruck
Old May 10, 2013 | 10:44 PM
  #440
GruesomeJeans
I don't know about algona days but the one I'm going to is on July 20th. The show I'm going to is going to have the raffle prizes and stuff back. I just need to get the $40 for both vehicles.
Old May 10, 2013 | 11:01 PM
  #441
FordFETruck
I'll probably go check it out
Old May 10, 2013 | 11:07 PM
  #442
GruesomeJeans
It should be pretty cool. Plus coastal has some damn good beef jerky.
Old May 10, 2013 | 11:13 PM
  #443
FordFETruck
Yeah lol. Last year's car show was kinda pitiful compared to some of the ones I've seen.
Old May 10, 2013 | 11:22 PM
  #444
GruesomeJeans
Yeah that's the mayor's doing. For some reason he has been taking things away from the show, which is why Ed decided to do his own this year.
Old May 11, 2013 | 07:30 AM
  #445
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Originally Posted by FordFETruck
C6 valve body looks pretty clean, why did you tear it apart? In the first picture, it looks like the right radius rod bushing might need replacing.
Old May 11, 2013 | 12:53 PM
  #446
FordFETruck
It shifts like a slush-o-matic, I bought a shift improvement kit for it, I'll be doing the mild one out of the two options. The whole inside of the transmission looks very clean. I also have a new N code servo to install with a different spring included in the kit. I noticed when the VB was bolted together, there was a blue tag that says NJ on it. Is that someone's initials?
Old May 11, 2013 | 12:59 PM
  #447
85lebaront2
No, that is the suffix on the VB part number, it was to identify them on the assembly line. My C6 had a nice firm shift for it's entire 119,000 + miles.
Old May 11, 2013 | 02:01 PM
  #448
GruesomeJeans
Mine shifts alright for what it is. I had it rebuilt last year at some point. Considering its turning 35s and the gears in it, it does ok.
Old May 11, 2013 | 02:12 PM
  #449
FordFETruck
It may have shifted better if the accumulator valve spring wasn't broken lol.
Old May 11, 2013 | 03:04 PM
  #450
85lebaront2
That could have had something to do with it. Be sure you adjust the 2nd gear band.
