1986 F-250 Progress Thread
Old May 20, 2013 | 10:29 PM
  #466
FordFETruck's Avatar
FordFETruck
Well, I got my new carb on and got the truck running. Runs MUCH better than the Edelbrock. Here's pictures.
The carburetor is a Summit Racing 600 CFM (Made by Holley) 4 barrel, vacuum secondaries carburetor. It's a re design of the Holley 4010, which was designed after the Autolite 4100. It has annular boosters, both primary and secondary. All I can say for performance is HANG ON when that pedal goes to the floor. Or even 1/4 throttle it lifts the front of the truck up from a slow speed. MUCH more power than the Edelbrock, runs smoother at cruise and is way more responsive. Oh, the exhaust also smells a lot cleaner with this carb than the Edelbrock. I'm very happy with it.
Oh, yeah. No more left turn or off idle stumble!
Old May 21, 2013 | 04:03 AM
  #467
GruesomeJeans's Avatar
GruesomeJeans
Hmm I spy a vacuum cruise control module right? How's that workin for ya? I had one on my 82 mustang but the diaphragm was trashed.
It's good that the carb is working for you. Mine is working well enough to keep the engine running. not good, not bad. The 6 mpg highway kills me though..
Old May 21, 2013 | 07:03 AM
  #468
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Looks nice, glad you finally got it sorted out.
Old May 21, 2013 | 12:35 PM
  #469
FordFETruck
It looks good and runs great, I'll get a running video later today. I need to set the choke differently, after 5 minutes of sitting the high idle comes back on and doesn't want to kick off easily. Could be that it only has 7 volts going to it instead of 12? I still need to look down the carb while it's running. But it sure is responsive.
  #470
FordFETruck
Oh, yeah the vacuum cruise control. Works perfectly.
Old May 21, 2013 | 02:10 PM
  #471
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Two lead choke element you need 12V.
... or you could just swap to an older Motorcraft single lead CM-4433-A (e5pz-9848-b) housing.
Old May 21, 2013 | 02:30 PM
  #472
FordFETruck
I think I'll just find a 12 V lead, where could I find one that's 12 volts with key on but not accessory? my fuse box seems to only have them that are key on and accessory.
Old May 21, 2013 | 02:46 PM
  #473
GruesomeJeans
Maybe something in the ignition system? Maybe figure out where the current lead is going and fix it to use 12v.
Old May 21, 2013 | 02:51 PM
  #474
FordFETruck
Summit Racing 600 CFM Carburetor Running on Ford 351W Engine - YouTube
The current lead is 7 Volts that goes to the alternator.
Old May 21, 2013 | 03:01 PM
  #475
BruteFord's Avatar
BruteFord
The red wire to the duraspark box.
Old May 21, 2013 | 03:05 PM
  #476
FordFETruck
The red wire to the duraspark box, coming out of the cab?
Old May 21, 2013 | 03:43 PM
  #477
BruteFord's Avatar
BruteFord
The box should have 2 groups of wires with plugs coming out of it, one with 3 wires, orange, green, and black iirc. And one with 2 wires red and white, that red one is keyed ignition 12V iirc.
Old May 21, 2013 | 04:38 PM
  #478
FordFETruck
I'll look at mine, but I took the truck for a drive, runs great at cruise. Very smooth. Idles so smooth you almost can't tell it's running.
Old May 21, 2013 | 06:41 PM
  #479
85lebaront2
Matthew, you could do what Ford did on some of the 351 chokes, use a relay, the 7 volts will pull the relay in, then use a fused wire from the battery. This way it will only heat once the alternator is charging.
Old May 21, 2013 | 07:03 PM
  #480
FordFETruck
Doesn't Gary use that setup? sounds like it would work good. What kind of a relay would work best for this?
