1986 F-250 Progress Thread
Old Apr 16, 2013 | 07:14 PM
  #361
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Matthew,
'87 has a larger bung than your years, and the sock pickup was last used in this year.
It is indeed an orphan (or red headed stepchild)
Old Apr 16, 2013 | 07:44 PM
  #362
FordFETruck's Avatar
FordFETruck
Larger bung?
Old Apr 16, 2013 | 09:21 PM
  #363
Archion's Avatar
Archion
Veteran: Marine Corps
yes, the 87 carbed manual pump, both 351W and 4650. is the forgotten stepchild of the fuel system industry. No one that I know of makes them aftermarket. There are a few remanufactures out there but they are disappearing slowly as well.
Old Apr 16, 2013 | 09:32 PM
  #364
1983F1503004x4's Avatar
1983F1503004x4
Originally Posted by Archion
yes, the 87 carbed manual pump, both 351W and 460. is the forgotten stepchild of the fuel system industry. No one that I know of makes them aftermarket. There are a few remanufactures out there but they are disappearing slowly as well.
So what would be your options if you needed a new fuel pump? Wouldn't earlier models fit?
I imagine the only other thing besides that would be an electric low-pressure pump with a fuel pressure regulator?
  #365
FordFETruck
Wow, I thought I was half dead in the water with mine, guess not. Now if only my main rear tank sending unit would work. When I first put gas in it last year, the sender didn't work at first but on the way home it worked, for a day. Then quit and never worked again. Sunk float maybe? don't know. I have a float from the old midship sender, if that's the problem then I'll have a free fix. I'll have to pull the rear tank someday.
Old Apr 16, 2013 | 09:43 PM
  #366
Archion's Avatar
Archion
The mechanical pump is on the motor and still available. if you have the in tank pump, those are available as are the senders. It is the senders for the mechanical pump systems that are made from unobtainium.
Same rules apply for 86-87 with the mechanical pumps.
Old Apr 16, 2013 | 11:36 PM
  #367
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Oh well, Thanks for that Matt.
They also seem to have been obsoleted by Ford for quite some time.
Which leaves me -0- options.
The socket on the 'Hot Fuel Handling' trucks pump/sender doesn't accept my harness.
I can't even buy one of those and strip the pump before installation.
Old Apr 16, 2013 | 11:38 PM
  #368
FordFETruck
I find it very odd how some years you can buy them at the auto parts stores and others it's some special red head step child part that nobody's hardly heard of. Yet you could go get one for a Chevy no problem for probably $50 at the local jip joint.
Old Apr 16, 2013 | 11:57 PM
  #369
ctubutis's Avatar
ctubutis
Originally Posted by ArdWrknTrk
I need to find the Unique senders/pickups for my truck.
'87, with a mechanical pump.
My senders are so bad I just go by mileage.
I ran out the other day... which was odd.
But then when I went to fill it, I could only get 13 gallons in.
The pickup must have rotted or fallen off and there is 6 gallons I can't get to.
Oh, yeah.... you sent me a PM this morning... I'll try and remember to look this up tomorrow morning, OK? You want I guess the sending unit for your stepchild?
Old Apr 17, 2013 | 12:03 AM
  #370
GruesomeJeans's Avatar
GruesomeJeans
I think he wanted it for his truck actually Just kidding!
  #371
FordFETruck
I repped Chris for that one lol.
Old Apr 17, 2013 | 12:11 AM
  #372
ctubutis's Avatar
ctubutis
Thanks, guys.
Old Apr 17, 2013 | 12:16 AM
  #373
FordFETruck
No problem lol.
Old Apr 17, 2013 | 12:19 AM
  #374
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm out of Rep's...
I found where Bill posted the number for the midship tank.
Green Sales has 13, but they are VERY dear.
I don't see the number for the aft tank, but I'm looking for the sender/pickup assembly.
Thanks Chris!
Old Apr 17, 2013 | 04:58 AM
  #375
Archion's Avatar
Archion
It all boils down to popularity and production numbers. Those years most, like over 80% were electric pump trucks. That's why the top of the sender is so large. They all used the same tanks. The mechanical pumps where being fazed out. Large Parts manufactures are not going to spend the money to tool up and produce such a rare part, it cost too much money to be worth it. And moreover, parts houses do not want dead money on the shelf. As for the chebby thing, as much as I dislike them, they were very good at using the same parts across the model line, unlike all the special versions Ford liked to put together. On the Chevy they are even the same tanks left and right, just two different senders across four tank numbers, and ford had a good 5-6 senders across two tanks.
