1986 F-250 Progress Thread
Old Apr 26, 2013 | 12:40 AM
  #391
GruesomeJeans's Avatar
GruesomeJeans
Yeah. I don't know the last time you drove past my house but there is a new addition to my pile of projects. A 71 Super beetle. It's got a lot of issues so I have to keep the truck going till I can get this little bug driving safely. Then I can park the bronco and really crack down on getting stuff done.
Old Apr 26, 2013 | 12:49 AM
  #392
FordFETruck's Avatar
FordFETruck
Last time I drove by your house you had the bronco backed in with both the axles out I think.
Old Apr 26, 2013 | 01:00 AM
  #393
GruesomeJeans
It was most likely only one. And that would have been after the tire fell off, I haven't had both axles out yet. Only one at a time. The Beetle I got is parked in front of the bronco now, down by the side of the house.
Old Apr 26, 2013 | 01:43 AM
  #394
FordFETruck
I'll have to look out for it next time we go by there lol. What color is it?
Old Apr 26, 2013 | 08:02 AM
  #395
GruesomeJeans
Kind of a dull yellow ish. if the Broncos gone it would be hard to miss.
Old Apr 26, 2013 | 10:07 AM
  #396
FordFETruck
What size engines do those have?
Old Apr 26, 2013 | 10:21 AM
  #397
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
1600cc from the looks of it.
Old Apr 26, 2013 | 10:22 AM
  #398
FordFETruck
Pretty small.
Old Apr 26, 2013 | 10:27 AM
  #399
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
And light.
No water cooling meant no water jacket, pump or radiator.
The 1600 single port came out in the mid-'60's, dual port around 1970.
Those engines could be hotrodded to 2l, but it's still an air cooled flat 4.
Old Apr 26, 2013 | 10:29 AM
  #400
FordFETruck
My riding lawnmower is 465 cc, and only 12 HP. I wonder what the HP rating is on these?
Old Apr 26, 2013 | 10:31 AM
  #401
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I added to my post above.
50hp stock
Volkswagen air-cooled engine - Wikipedia, the free encyclopedia
Old Apr 26, 2013 | 10:42 AM
  #402
FordFETruck
Thanks for the link, Jim. They sure are tiny looking engines.
Old Apr 26, 2013 | 01:26 PM
  #403
GruesomeJeans
He is correct, it is a dual port 1600cc. But the Haynes manual I have rates them at 60 hp the way I described it when I did a test drive, a lawnmower with a clutch. Being that the engine is in terrible shape, it needed about half throttle and a slow clutch release or it would have died. If it died then that's the end of the test drive, it was too difficult to start the first time.
The motors are super tiny but what it lacks in power, it makes up for in simplicity. No water cooling means I have only 3 major fluids to worry about, brakes, trans, and oil. I don't have to be concerned with the damage from the coolant or the mess it causes.
Old Apr 26, 2013 | 01:31 PM
  #404
GruesomeJeans
Let's see if this will work.
I've gone over all the starting stuff besides the plugs. I have a spark tester that is just a spark plug stuck inside a piece of rubber hose so you can see the spark. It had such a strong spark that my step dad got shocked while holding the rubber part of the hose that was farthest away from the plug. I'd say the ignition is good for the most part. We are thinking it has no compression but haven't checked yet.
Old Apr 26, 2013 | 01:45 PM
  #405
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
They like to burn the exhaust valve on #3.
