- wiring under the distbuter need help
- Intake Manifold - 400
- Restoration parts and vin# results..?
- 460 to 300 swap in 77 F150
- Free-Wheelin'
- Heavy hauling
- I havent seen one of these in a while.
- Bed Removal on a 74 F250
- Disc brakes from 76 crew cab
- The math for my Rpm's don't add up
- Won't accelerate when temp reached...
- 460 conversion pics needed
- Automatic shift lever connection
- Need Fuel Selector Valve for 77 F-250
- Found a pile of parts
- Engine turns easy, but won't start???
- still looking
- what brand bedliner fits a 79 8' bed the best?
- how important is the heat riser system?
- steering box leaking at bottom
- power brakes & steering
- Need A Tranny Bad!!!
- fog lamp colors, blue, amber, clear, whats the advantage?
- '79 F 250 4x4 460 swap
- Do I bend the tabs on axle lock washer?
- 78 79 tilt steering column
- Couple year and model questions
- 76 high boy breaks + body
- Tire and wheel size questions for 1978 F150 4x4
- 79 Needs New Tranny
