Need A Tranny Bad!!!
Old Aug 18, 2005 | 12:38 PM
MidwestKid34's Avatar
MidwestKid34
Exclamation Need A Tranny Bad!!!
I have a 79 f100 short box 2wd with a 300-I6, i had a 3 spd in it. The 3 spd puked , where is the best place to get a 4 spd or 5 spd with O/D. That would be an easy swap, thanx.
Old Aug 24, 2005 | 05:26 PM
1975Ford's Avatar
1975Ford
You can usually find a good used one at a wrecking yard that's sells parts.
Old Aug 25, 2005 | 06:47 PM
RTM's Avatar
RTM
I pulled a 5 speed from a 2 wheel drive 300 truck. I can make you a real good deal. Send me PM if your interested. Keep in mind you will have to fab a Hyd clutch set up.
