- clutch replacement sequences?
- 4000 rpm = 100kph or 60 mph bad bad
- speaker question
- 86 captain chair issues
- Stumble at high RPM
- NOS Box Sides
- Because someone here will know.
- would a bad vacuum booster cause weak brakes
- F100 original paint?
- where is the firing order 1 mark at on the pro comp distributors?
- wheels
- RF turn signal only works with headlights off
- '81 F150 won't idle until warm
- 1986 F150 No Injector Pulse
- 4X4 Finally!
- 1985 ford f150 fuel gauge problem
- 1982' F100 Restoration
- *EMERGENCY* Parking Brake Help Needed
- Chance to buy an early Bronco
- fuel tank
- need help installing the pro comp hei distributor
- replacement dash
- 1986 F150 Unknown Loose Wires
- 82 F100
- Build thread, (I hope). 86 F150 4x4 SWB
- EFI question
- successful door adjustment and hinge pin r&r
- 1982 F100 cranks, but won’t start
- Vacuum canister (coffee can)
- We're the #7 Thread on FTE
