harmonic balancer removal
Old Apr 10, 2002 | 06:52 PM
1ole4d's Avatar
1ole4d
hey ya'll...I'm having a problem removing the harmonic balancer on my 351M. I rented the tool from work but I cannot get that sucker to slide off. Any ideas???
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old Apr 10, 2002 | 09:05 PM
shazam's Avatar
shazam
OK Did you remove the bolt that holds it in place.
What I do is remove the bolt take the washer off reinstall just the bolt then put the wheel puller on and hit it with an impact wench off it comes ...
Hope this helps
ShaZam
Old Apr 10, 2002 | 10:09 PM
1ole4d's Avatar
1ole4d
Well...after much swearing and wrenches flying the harmonic balancer finally gave in and BROKE! One of the bolts used to hold it to the balancer broke off inside so now I only have 3 bolts to hold the pulleys on. I said screw it and put the water pump back on and put it all back together. I think I'll just keep adding oil and replacing the track arm bushings every month. Whadda think......
Old Apr 15, 2002 | 08:15 AM
bondo man's Avatar
bondo man
i had the same problem 1 time. make sure u take the pullies off, then the bolt and washer. i forgot the washer and broke the balancer trying to pry it off. hope that helps!
Old Apr 16, 2002 | 09:00 AM
Ugly's Avatar
Ugly
Trstrugar
13
Feb 18, 2017 08:15 AM
36545f150
15
Feb 18, 2017 08:13 AM
genn
1983 - 2012 Ranger & B-Series
Oct 29, 2014 08:37 PM
77'FORD_man
19
Apr 18, 2012 11:51 PM
dburgess
May 11, 2004 11:19 AM
