differences between a 351 c/m/w????????
Old Apr 15, 2002 | 08:40 PM
Big Blue4x4's Avatar
Big Blue4x4
Old Apr 25, 2002 | 03:10 AM
dogman312's Avatar
dogman312
What are the differences between the 351 clevland/winsdor/modified .....Yeah i know this may seem like a dumb question but i have learned more about chevy motors and not that much about ford motors even though i am a FORD man all the way .....well n e ways which one out of the three makes more power and what r the differences between them ??????
Old Apr 25, 2002 | 05:46 AM
xyfalcon500's Avatar
xyfalcon500
The tech article section and previous posts should be able to answer your question about what the differences between the motors are. As to which one is the best/most powerful etc, you will get some debate. Definitely, the 351m is not a performance motor, and although most performance parts made for the 400 will fit it, the question would be 'why a 351m and not a 400?'
The 351C has traditionally been the performance 351 cu in engine, because there have always been hard-core performance parts available for it, even though some can be very pricey, whereas the 351w was neglected for a very long time with regard to high-performance arts availability. However, it is possible to build a powerful 351c or w, for example, a guy here in Australia put a 744hp naturally aspirated 351w into his 69 falcon. Similarly, outputs that high are achievable with a 351c (think NASCAR and pro stock drag racing).
Old Apr 25, 2002 | 07:10 AM
bbtkd's Avatar
bbtkd
OK - the 351W is the largest of the 289/302 family. The blocks are pretty decent, having thicker cylinder walls than the 351C. The heads are not very good compared to the 351C.
The 351C is the base engine of the Cleveland 335 engine family (which never had a 335ci engine in it - perhaps early plans that changed). It has about the best production heads ever made. The blocks are good except the cylinder walls are pretty thin and you can encounter overheating by only boring .030 over - in some cases.
The 400 is a stroked 351C with a raised deck (so intake is wider). They take the same heads as the 351C (some slight variations). The 400 is not known for high revs, but is known for low-end torque and lots of it. The engine is a sleeper as it was never shipped in performance trim. It has the best performance POTENTIAL of any engine I know of. The 400 takes the same crank design as the 351W - in fact if you put a 351W crank in a 400, you get...
... the 351M. In 1975, ford wanted to retire the 351C but wanted a 351 engine in the 335 family - so they stuck a 351W crank in the 400 block and then they could discontinue the 351C crank, block, rods, pistons, intake, etc. I've never seen it in print - but sure seems like a production cost issue in retrospect. The 351M is a compromise - the long rods hamper revs without the benefit of the cubes of the 400. Simple fix if you are stuck with a 351M - swap the crank, rods (or is it pistons - can never recall which) and turn it into a 400.
Some have taken the Cleveland heads and machined them to fit a 351W and called it a Clevor. For me, if you have a choice of all of the above I would go with the 400 for the street, but a 351C for the strip. The difference is the revs - 400 is great for street performance or low-rev pulling. The 351C revs nicely , particularly with the 4V heads. I've probably told you more than you wanted to know...
Old Apr 26, 2002 | 03:56 AM
GT40man's Avatar
GT40man
ommm, no. they never put a 351w crank in a 400. it wont fit. having said that. the 351m is a destroked 400. the crank on a 400 is a 4 inch stroke. the 351m is a 3.5 inch stroke. all of fords 351 engines used a 3.5 in stroke.
Old Apr 26, 2002 | 10:57 PM
bbtkd's Avatar
bbtkd
I'm not saying you are wrong, but I was quoting the American V8 Engine Data Book (p133).
Old Apr 26, 2002 | 11:59 PM
Mil1ion's Avatar
Mil1ion
Here is another source for info if you're interested.
http://www.oemfordparts.com/faq/smallblockv8.htm#351M%20(MOUNTED)%20AND%20400
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
Need to decode your 78 Truck data plate? click here
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven!
[/font]
Feel free to visit my website.
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color =red] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V [/font]
Old Apr 27, 2002 | 02:48 AM
Torque1st's Avatar
Torque1st
Posting Legend
The Clevor engine will make Horsepower! But you have to spin it up. The cleveland heads really wake up that engine. It all depends on what you want, low end brute torque (400) or high rpm horsepower (clevor). Take your pick!
over!
Old Apr 27, 2002 | 08:29 PM
GT40man's Avatar
GT40man
clevors cost more to build that either a windsor or a cleveland.
Old Apr 27, 2002 | 08:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are a few "custom" parts involved. I believe you can get the pushrods and other parts from:
http://www.midwestmotorsportsinc.com/
You have to call them tho, they don't list the parts online or in their catalog. They have trick heads already modified and rebuilt if you want them also. The std heads are real easy and cheap to get and the modifications are simple.
over!
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
