bad motor mount?
Old Apr 17, 2002 | 10:06 PM
teamwizard's Avatar
teamwizard
Post bad motor mount?
hey guys, think i have a bad motor mount, im not sure if its fixable. i'll try my best to explain. the mount is for a 351m/400, there is one piece of steel the bolts to the frame, a piece of rubber, then the other piece of steel that bolts to the engine. now holding the 2 pieces of steel is this big heavy duty rivet type bolt with a thick rubber washer or grommet type thing at the head. that washer thing is gone, so i can like twist the steel pieces around in cirles.
do i have to get a new mount? can i just cut the rivet, and run a grade 8 bolt thru there? help me out please. if i need new mounts, whats the best place to get them?
thanx
Gabriel
Old Apr 17, 2002 | 10:48 PM
Franklin2's Avatar
Franklin2
bad motor mount?
Get a new mount. You should be able to get them anywhere you get auto parts.
Old Apr 18, 2002 | 07:35 AM
shazam's Avatar
shazam
bad motor mount?
Yes I'd say get new mounts too . and then add some extra beef to it by adding a piece of chain to the driver side of the motor where the power steering pump mounts and around the frame. Get a piece long enough that will loop from the head all the way around and back to the head with about 1" of slack, then add a 4" X 3/8" bolt with big washers on each end in between the motor and the frame to where you can just get the nut started, then tighten with impact till chain is really tight. You'll never break another motor mount with this set-up.
If you happen to have a real Monster 400 like mine you might bend the frame though..
Old Apr 18, 2002 | 01:27 PM
teamwizard's Avatar
teamwizard
hey shazam, im not sure i exactly understand how to do the chain thing. is there any way you could send me a pic or some type of drawing. its a great idea, i just dont wanna mess anything up.
thanx
gabriel
teamwizardL7(No Email Addresses In Posts!)
Old Apr 18, 2002 | 09:13 PM
Vampiro's Avatar
Vampiro
bad motor mount?
gabriel replace motormounts in pairs. and don't take it to places like canadain tire. i learnt my lesson after 4 h and 140 bucks! yeah you do need new mounts bud. to lift i don't suggest by the oil pan. maybe the harmonic balancer might be better
Old Apr 19, 2002 | 03:39 PM
teamwizard's Avatar
teamwizard
hey, vampiro--of course i wouldnt lift it by the oil pan!! i have my engine out, so changing the mount will not be a big deal. shazam can u explain exactly how to chain the engine or send pics!!?
gabriel
Old Apr 19, 2002 | 10:43 PM
GT40man's Avatar
GT40man
bad motor mount?
