EGR block off plate
Old Sep 11, 2002 | 12:52 AM
rcruzer's Avatar
rcruzer
EGR block off plate
i was wondering if any one has seen an EGR block off plate for a all stock 400. i have fab. my own plate, but i would realy like a better one. i guess a spacer to replace the EGR one on there on would work also.
i would like to read about what ya'll think about running the 400 without the EGR in general. i plan the install larger jets in the carb to richen the mix some.
I have heard the only efffect of not using the EGR is that the exhaust gases are not being recirculated back into the combustion chamber , which cause the air/fuel mix to be lean. true...not true what do you think
thanx a lot
rcruzer
Old Sep 11, 2002 | 07:15 AM
xyfalcon500's Avatar
xyfalcon500
EGR block off plate
One thing you will notice if you block off the egr is that your carb will take longer to heat up to running temperature. Not a problem if you don't live in a cold area or don't drive it much.
Old Sep 11, 2002 | 11:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
EGR block off plate
Your engine will ping at part throttle.
Old Sep 12, 2002 | 01:17 AM
Brian S's Avatar
Brian S
EGR block off plate
The EGR is closed at idle. It's function is to lower combustion temperature by contaminating the ports with an inert gas. Emission
type carbs run very lean and would produce harmful Nox emissions when chamber temp exceeded 2500 deg.
If the EGR port is blocked off at the head, it would take longer for the manifold to warm up.
To avoid detonation, you may haxe to use a higher octane fuel, less ignition timing, a richer A/F ratio, or a cooler thermostat.
I wonder if a ping sensor could be used to open EGR when needed.
Old Sep 12, 2002 | 01:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
EGR block off plate
>needed.
Now that is a Great idea! Have you ever found a ping sensor that works tho for reasonable $$? Vacuum solenoid switches are cheap in junkyards. Of course just backing off on the vac advance would work too.
Old Sep 12, 2002 | 01:26 PM
beartracks's Avatar
beartracks
EGR block off plate
I would replace the EGR plate with a spacer. They sometimes get eaten up internally and leak causing odd problems.
Old Sep 15, 2002 | 02:42 AM
Brian S's Avatar
Brian S
EGR block off plate
I not sure how the knock sensor works or what it controls. I wonder if a stand alone system can be built.
Who says it has to loose power with an inert gas. Couldn't the EGR valve be used to supply a high octane fuel like propane, natural gas, alcohol, etc?
Old Sep 15, 2002 | 03:09 PM
highcountry's Avatar
highcountry
EGR block off plate
Brian,
Basically a knock sensor is a piezoelectric device screwed into the engine. That means that when a detonation occurs a very small amount of current is produced by the sensor. That pulse is sensed by a module which in turn retards the ignition timing. What you could do is build a module that senses this current and then opens an electronic EGR soleniod which is readily available in a junk yard off of many vehicles. It would help to snag one off of a vehicle for which you had a schematic so you could see how it works. You would then need to decide what input you wanted to use to tell the module to close the soleniod and thus the EGR valve. You could time it or make it so that when you back out of the throttle it closes. Whatever you wanted since you would be building the module. I don't know how much electronics theory you have but with a little inginuity it would work. Would be handy as a safty catch on the track or using nitrous (I think that would work, be careful there and consult someone with nitrous experience). But then again turning down the timing works too. That is the basics, to give you an idea of what would be involved.
Old Sep 15, 2002 | 04:30 PM
Quantrex's Avatar
Quantrex
EGR block off plate
Old Feb 5, 2008 | 10:11 PM
jw43's Avatar
jw43
My 460 engine is pinging and its because the head needs to have a exhaust plug how do I replace or is there a part for this to close it off and stop the pinging.
Old Feb 6, 2008 | 07:51 PM
mark a.'s Avatar
mark a.
I just put a soft plug in the intake hole under the spacer. I don't remember the size off hand. That way you can run the stock spacer plate.
avvidclif
Jul 10, 2016 11:11 AM
TREELIZARD
6.7L Power Stroke Diesel
17
Jan 22, 2014 05:42 AM
TheThickster
Aug 13, 2010 09:56 AM
squidMaurin
May 18, 2009 10:32 PM
wook540
Apr 4, 2007 09:55 AM
