Summit Carb
Old May 12, 2021 | 12:38 AM
F-250 restorer's Avatar
F-250 restorer
Summit Carb
Does the Quick Fuel adjustable secondary unit fit on the Summit 600 vs?
They used to allow one to ask questions about the products on the summit site, but it appears that function is gone.
Old May 12, 2021 | 08:13 PM
F-250 restorer
Are you kidding me? Not a single member has a Summit Carb and wanted to install a QF adjustable secondaries diaphram?
Old May 13, 2021 | 09:44 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Chirp, chirp.
Did you try and call them? Sometimes you get a good parts person.
Old May 13, 2021 | 10:24 AM
ford390gashog's Avatar
ford390gashog
The 63-1QFT fits.
Old May 13, 2021 | 10:44 PM
F-250 restorer
Originally Posted by ford390gashog
The 63-1QFT fits.
Gashog, I think that from now on when I have a question, I'm just going to bypass the forum and PM you directly. It would be so much quicker. Thanks. I thought that since several parts on the summit are Holley, the Secondary dia. most likely was as well.
Do you have any experience with E. fans? I have a dual Contour setup. Both motors are single speed. I'd like to make one come on a bit later than the other, so I don't get such a spike that my msd stumbles, and was wondering if I could use one of the current delay gizmos on ebay and set it for maybe 10 seconds delay. What do you think?
Old May 13, 2021 | 10:53 PM
ford390gashog
You can experiment with a delay relay or try driving a PWM module. I have even seen people use 12v stereo amp capacitors inline to cure the hard start of the fans. I haven't had the hard start issue or ignition drop out like you posted in the other thread. There also was a company selling soft start fan controls all packaged together. I believe it was a fixed PWM, capacitors and mofsets and was pretty expensive.
Old May 14, 2021 | 09:52 AM
F-250 restorer
Hey Gashog. Thanks again. I really like the dependability of the relay system I have. They are easy to change if need be, and I carry a couple extra with me. I also like the cost. I have seen the soft start controllers (www.autocoolguy.com) but they run about $170 and who knows how long they (it) will last. I will try the delay relay for now.
Also, thanks for the help with the secondary adjustable dia. Cheers.
POPAJON
Jan 17, 2011 09:17 AM
96sherm
Apr 1, 2008 10:28 PM
Chas1234
Aug 5, 2003 03:05 AM
fordeverpower
Aug 2, 2003 10:13 PM
