R 134
Old Aug 27, 2023 | 01:30 PM
5851a's Avatar
5851a
R 134
I did not know R 134 had a new style can tap. Newer truck sets in building most of the time now since not much need. AC didn't work. 11 years it always has, thought I would get gauges and maybe see if it needed a little. Picked up freon and now I see new can and self sealing valve top. I don't get out enough.
Old Aug 27, 2023 | 03:56 PM
440 sixpack's Avatar
440 sixpack
Yes it's always been that way. if you get good gauges they'll come with hoses to fit either one.
Old Aug 27, 2023 | 04:33 PM
77 HOS's Avatar
77 HOS
If you have one the old hoses to charge with r134a you can use it on the self sealing valve just have to pay attention to where it's open at.
I hooked the can to it and began turning the valve on the hose until it began to let freon out. Let say it was 3 turns.
Then I hooked up to truck and gave it 4 turns to allow it to fill. If you go too many turns it will block it off, or break the self sealing valve forcing you to release what you don't use into the atmosphere. (Illegal)
Old Aug 28, 2023 | 09:37 AM
5851a's Avatar
5851a
Found the correct valve for less than $8 so I just ordered it, everyone one needs more tools.
Old Aug 28, 2023 | 10:23 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
R 134a changed a few years back to self sealing cans. The can tap is different from the old puncture to use and self sealing. as far as having a guage set that does "both" it would need conversion hoses that connected to flare (r12) and acme (r134) they do exist. A new can tap might be worth the $20 to correctly dispense the freon.
Old Aug 29, 2023 | 10:10 AM
5851a's Avatar
5851a
I have dedicated hose sets for both but haven't needed either for years. I still have R12 cars and the newer is 134, just didn't know about the new can style.
Old Aug 30, 2023 | 08:58 AM
headloct's Avatar
headloct
New style self sealing can tap has a flat tip on the center piece. Old style is pointed to puncture the can. Old style will work on new style self sealing can but may not reseal if you don't use the whole can.
Old Aug 31, 2023 | 01:03 PM
monckywrench's Avatar
monckywrench
When I use a piercer I don't try to save partial cans.
BTW piercers are handy for many things like draining carb cleaner or other solvents out of spray cans that lost pressure and dumping spray paint when a can has a clogged valve. I'm too lasy to connect my airbrush to a spray can using a piercer (I collect piercers) but will eventually give that ago since spray can nozzles misbehave so often.
jart
2009 - 2014 F150
Jun 18, 2021 02:08 PM
QUINCE
Jun 6, 2020 05:53 AM
918eva
Mar 20, 2010 04:35 AM
Dave93
Aerostar
Aug 10, 2006 01:39 PM
oldRedTruck
Aug 11, 2005 07:53 PM
