AC Compressor Removal - Not Service
Old Aug 27, 2023 | 06:28 PM
LandAndStone's Avatar
LandAndStone
Desk Jockey
1977 351M AT AC
The last leak on my truck is the rear of the intake. I plan on simply removing, refreshing and resealing the intake. The only question I have is on the AC compressor (York style, converted, works great).
The shop manual says I need to discharge the system, a procedure requiring vac pumps and refrigerant pumps. An AC tech I am not.
Question: Should I take to my local AC guy to safely discharge, do my intake work, and then return to AC guy for a recharge?
Old Aug 27, 2023 | 07:07 PM
dlburch's Avatar
dlburch
if you actually have to remove the compressor/bracket, there should be enough slack in the hoses to carefully move the compressor far enough without disconnecting them...
Old Aug 27, 2023 | 07:26 PM
tbear853's Avatar
tbear853
You can move it over onto the inner apron. I've rep[laced the heads even, placing the compressor over there secured with rope, might remove the washer water jug though.
Does it have the service valves still on it? If so, turned all the way inward the compressor is isolated, just don't pour oil out. Leave the valves on the hose ends.
Old Aug 27, 2023 | 11:51 PM
440 sixpack's Avatar
440 sixpack
No reason to remove the compressor. I've pulled engines and replaced them numerous times with the compressor pulled to the side.
Old Aug 28, 2023 | 07:08 AM
LandAndStone
Desk Jockey
Glad to hear it. Thanks for the direction.
Anonymous12
78
Jun 7, 2023 07:38 PM
Falcon731
May 4, 2009 03:50 PM
oxbass78
Apr 11, 2007 12:31 PM
Chris_ce
1983 - 2012 Ranger & B-Series
Jul 6, 2003 08:44 AM
