electric fuel pump
Old Apr 29, 2000 | 10:53 PM
SLEMON's Avatar
SLEMON
electric fuel pump
When I shut my truck off tonight the fuel pump in the rear tank kept running. I switched to the front tank and that one would run also. The only way I could get them to stop was to disconnect the battery. I hooked back up and it would still run. Now sitting with battery unhooked until this can be solved. Is it safe to drive when I hook battery back up and try to get to work?
Old Apr 29, 2000 | 11:11 PM
PAUL_2's Avatar
PAUL_2
electric fuel pump
Sounds like the fuel pump relays are stuck open and allowiing the pumps to continue to run . What model yr is your truck ? Engine ? Im sure one of us can tell you where the relay is located depending on the model yr . Most all of the later model fuel pump relays are located in the same housing as the EEC IV , ABS ...left side fender well area , they are all marked , black plastic housing . I got mine to shut off by tapping it until I got a new one .
Paul
Old Apr 29, 2000 | 11:28 PM
SLEMON's Avatar
SLEMON
electric fuel pump
It is a 1990 with a 5.0
Old Apr 29, 2000 | 11:31 PM
SLEMON's Avatar
SLEMON
electric fuel pump
1990 F-150 with 5.0
Old Apr 29, 2000 | 11:45 PM
SLEMON's Avatar
SLEMON
electric fuel pump
Went out and tapped on it and it worked. Thanks
Old May 1, 2000 | 08:14 AM
Herby's Avatar
Herby
electric fuel pump
This is pretty scary, mine did the same exact thing on Saturday. Same year truck. Y2K related? I did the same thing, unhooked the battery for awhile. I hooked it back up later and it was fine. Guess I'll head down and pick up a fuel pump relay just in case.
Bill
Old May 1, 2000 | 04:15 PM
maveric's Avatar
maveric
electric fuel pump
joejoebo
1983 - 2012 Ranger & B-Series
Oct 21, 2012 11:39 AM
ArdB
Oct 18, 2010 08:47 AM
jackson22
Engine Swaps
Jun 15, 2009 11:37 AM
AC-MAN
Dec 12, 2007 12:06 AM
Tenn01PSD350
27
Apr 14, 2006 09:31 AM
