MAF sensor cleaning, Ping, '94 Exploder
Old Jul 3, 2003 | 09:28 AM
unclemart's Avatar
unclemart
Question MAF sensor cleaning, Ping, '94 Exploder
I've read that instead of replacing the MAF sensor ($130), you
can carefully clean the elements. Has anyone had experience with this?
Looks like you need a special Torx 25 with hollow tip?
Old Jul 3, 2003 | 10:07 AM
viiidude's Avatar
viiidude
These links contain a couple of articles on how to clean a MAF.
http://www.fordscorpio.info/cleanmaf.htm
http://www.tccoa.com/articles/intake/#
Good Luck
Old Jul 21, 2003 | 11:20 AM
Ben Nemec's Avatar
Ben Nemec
I have cleaned the MAf on my 94 explorer which also has a ping problem. It had more power and less of a ping but the ping was still there. I got the screws out with the craftsman screw out damaged screw removerand replaced them with normal sloted head serews. I cleaned the elements with carb cleaner and let it air dry befor I put it back on.
Old Jul 26, 2003 | 10:11 AM
Rockledge's Avatar
Rockledge
Very good informative thread on the subject right here at FTE, too! Take a look:
Cleaning the MAF
