cooling system
Old Jul 3, 2003 | 05:57 AM
stu34explorer's Avatar
stu34explorer
cooling system
Hi all have a question would like some insight on i have a 98 explorer 4wd
with 6 cylinder. I am planning a trip to florida and would like to take care
of some things before leaving it seems coolant seems to be replace was
wondering the best procedure on that. I was all talking to someone in
regards to thermostat they say on that model that there is a 2 stage
thermostat and it costs more is that true and should it be replaced i have
53000 miles. If so is it a big job to replace that the one guy said to
remove throttle body and other parts as well. I also see serpentime belt
looks bad what type job is that to do. I am mechanically inclined i rebuilt
a motor in a mitsu eclipse and pulled mototr out and reinstalled.
Thank you
stu
Old Jul 3, 2003 | 12:00 PM
stubborn1's Avatar
stubborn1
cooling system
I guess we would need to know what engine you have to determine how hard it is to replace the thermostat.
I have the 4.0 OHV, and replacing the stat is very easy. I do it every time I flush the coolant (about every 30k miles). I remove the stat before I flush, flush the system, install new stat and gasket. I figure its a cheap way to go since the stat and gasket are only about $6.
funfunstuie
New Member Introductions
Apr 12, 2016 03:21 PM
thundersnow70
19
Jun 24, 2015 09:50 PM
stu78
Mar 7, 2007 12:02 AM
stuwiley
Aug 24, 2004 08:28 PM
stuc
Oct 23, 2001 02:24 PM
