Lighting on instrument panel out
Thanks list....Appreciate any suggestions here.
The same happend to me with my '95 Explo, you have to take out the dash, on the back there are 4 black bajonetfittings, they hold the bulbs.
Removing the dash is a bit tricky, first disconnect the batterycables (airbag!) start with the panel below the wheel, included the hood release handlebracket, ashtray and the screws in the centerconsole.
Remove the steel reinforcementpanel below the wheel.
Remove the bezel retainingscrews, tilt the wheel down to lowest position.
Pull the top of the instrument cluster bezel outward while disengaging the lower half, remove the bezel.
Remove the 4 screws that hold the instrumentcluster and manouvre it out (push in the hazardswitch for space).
Be carefull with the tiny cable that pulls the shifter arrow.
Good luck, Tony.
Removal and Installation
1. Disconnect the battery ground cable. For additional information, refer to «Section 414-01».
2. Remove the instrument panel center finish panel. (around radio and a/c controls)
1 Remove the screws.
2 Disconnect the connectors and remove the instrument panel center finish panel.
3. Remove the hood latch release handle.
2 Lower the hood latch release handle out of the way.
4. Remove the instrument panel steering column cover.
2 Remove the instrument panel steering column cover.
5. Remove the instrument panel steering column opening cover reinforcement.
1 Remove the four screws.
2 Remove the instrument panel steering column opening cover reinforcement.
6. Position the column gearshift lever in the low position.
7. Partially remove the instrument cluster finish panel.
2 Position instrument the cluster finish panel to gain access to electrical connectors.
8. Remove instrument the cluster finish panel.
1 Disconnect the connectors.
2 Remove instrument the cluster finish panel.
9. Note:
Illustration shows steering column removed for clarity.
Remove the instrument cluster.
2 Remove the transmission range indicator and position the cluster forward to disconnect the three electrical connectors on the back.
3 Remove the instrument cluster.
10. To install, reverse the removal procedure.
Bulbs are the black sockets on rear. 194's buy em anywhere.
