92 Engine noise...tic
Old Jul 23, 2005 | 08:47 AM
sjwoody's Avatar
sjwoody
I haven't had any performance issues with the vehicle for a long time, and still don't, except recently I've noticed a ticking noise that seems to come from on top of the engine. I think it's always been there since I've owned it, but it seems exceptionally loud now. Even my 14 year old has made a comment about it! I've done a visual check of the plug wires (the sound is similar to a wire arcing whenever the plug fires) and can't find anything. Could injectors make a similar noise?
I should also say that I only notice it at idle, regardless of warm or cold engine. I suspect it's there when driving too, but I can't hear it.
Old Jul 23, 2005 | 09:38 AM
E-150's Avatar
E-150
More than likely it's the lifters. You'll need to take the heads off to replace them. Also it could be warn rockers or both.
Old Jul 23, 2005 | 10:45 AM
mrshorty's Avatar
mrshorty
The fuel injectors do make a clicking noise. I've heard of cases where a bad computer ground causes the injector noise to be extra loud. Valve lifter noise is also common to these cologne engines. Make sure the oil level is correct. Can you usea stethoscope or equivalent to isolate the noise better?
Old Jul 25, 2005 | 05:30 AM
sjwoody's Avatar
sjwoody
yeah...I've used a stethoscope years ago...I hadn't thought of using one for this. I'll give it a try.
xtremexj
Oct 22, 2013 09:43 PM
Sunline Fan
Dec 18, 2011 09:48 PM
MCLEM
1997 - 2003 F150
Mar 18, 2008 02:05 PM
hi-jacker
Jul 6, 2005 03:36 PM
biederboat
Aerostar
Jul 11, 2001 06:28 AM
