bad computer ground
Old Jul 23, 2005 | 04:13 PM
kclyki02's Avatar
kclyki02
bad computer ground
92 Ex. 4.0 OHV, so we traced the fuel pump problem on my ex down from the fuel pump relay to the ground on the computer being bad. Any way to fix this without putting in a new computer? Its been over a week and its driving me crazy.
Old Jul 24, 2005 | 06:58 PM
mrshorty's Avatar
mrshorty
I'm a little confused. You traced the problem to bad computer ground. By this, do you mean that the ground wire between the computer is bad, or is it a bad connection inside the computer? Is it possibly in the computer's 60 pin connector? If the wiring fault is outside of the computer, you should be able to fix it without replacing the computer. If the fault is inside the computer, then you'll probably end up replacing the computer.
Jcampe
Feb 16, 2016 07:01 AM
Ford_Six
General Automotive Discussion
Feb 10, 2015 11:12 PM
shia1
1978 - 1996 Big Bronco
Dec 19, 2009 12:59 PM
854x4
1983 - 2012 Ranger & B-Series
27
Sep 16, 2009 10:00 AM
