gears & chips
Old Aug 14, 2002 | 07:00 PM
groundrat's Avatar
groundrat
gears & chips
Old Aug 17, 2002 | 12:06 AM
koja's Avatar
koja
gears & chips
does anybody know where you can get 3.89 or 3.90 for an 8.8 rear?i can find them for the front 44.going to 33x10.50x15 bfg,s.Installed diablo chip,love it,uses less pedel.truck still gets 14-15 mpg with ac at 75 mph. 95 f150 4x4 ec,catback exhaust,jacobs ignition,3"lift
Old Aug 17, 2002 | 10:08 AM
edenroadmaster's Avatar
edenroadmaster
gears & chips
try Randy's ring and pinion web sits is www.ring-pinion.com
Old Aug 17, 2002 | 10:26 AM
Redneckerson's Avatar
Redneckerson
gears & chips
Due to the configuration of the ring and pinion on the 8.8 you can get 3.55's 3.73's or 4.10's for the ballpark ratios your looking for. I know the dana 44 ifs has a 4.09 optional ratio(which i'm looking for if anyone has a good set) but not sure about the other ratios.
RSH
Old Aug 17, 2002 | 08:27 PM
markus's Avatar
markus
gears & chips
I know you can get 3.73 for the Dana44. Just remember if you get 3.73 you can keep the stock carrier. If you go with anything higher than 3.73 the stock carrier must be replaced too.
Old Aug 17, 2002 | 08:58 PM
MustangGT221's Avatar
MustangGT221
gears & chips
Get 3.73 or 4.10s front and rear, those are the only two available. For the rear, I'd recommend ford racing gears from summitracing.com at a hair under 200 bucks.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
