Check Engine Light
Old Aug 15, 2002 | 02:56 PM
Gunner Ozzie's Avatar
Gunner Ozzie
Post Check Engine Light
Hello all,
I need a little help trying to cypher this check engine light. I got a 96 F150 with 4.9L 5 speed. Got a check engine light a week ago so had the kind folks at Auto Zone scan it for me. Came up with P0135, P0141 and P0155 codes (all 3 O2 sensors). Spent the $150, changed the sensors, cleared codes and lo and behold 2 days later the light came back. Went back and they cleared the codes again. You guessed it, couple of days later the light is back on but this time the engine will intermittently run rough (almost like running on only 3 cylinders) but will smooth out if I push in clutch and rev it up some.
Went out and bought a scanner today and the same 3 codes are back. I find it hard to believe that I got 3 bum sensors so I sure hope someone out there might have some good gouge to point my troubleshootin efforts towards.
Thanks,
Ozzie
Old Aug 15, 2002 | 05:01 PM
MIKALA1's Avatar
MIKALA1
Check Engine Light
My truck is a 93 f150 4.9 and it was doing what yours is doing and I had recieved a recall from FORD and was for the fuel press/reg. and that service was done and a new fuel filter was put on and it was very dirty. The truck runs with new power. and fuel mileage is up.
check it out. I think this is your problem also. GOOD LUCK.
HANS.
Old Aug 16, 2002 | 04:14 PM
Gunner Ozzie
Check Engine Light
Thanks for the info Hans,
Threw on the fuel pressure tester and I read 52 PSI with key on and 48 with engine running so it ain't the regulator or filter. Anybody else got any ideas? I got the whole weekend and alot of liquid refreshments to try and cypher this critter. Need to get er fixed soon cuz the war department wants her Expy back!
Thanks
Gunner
Old Aug 19, 2002 | 05:39 PM
little_johnny's Avatar
little_johnny
Check Engine Light
my fi50 w/ 351 has been doing the same thing.if ya ever figure it out could you let me know...all the mechanics ever want to do is keep changing 02 sensors and cleaning injectors (every 5k miles).gotta be something else causing the code
thanks
chris seamusmac at earthlink.net
Old Aug 20, 2002 | 10:25 AM
paulhenderson's Avatar
paulhenderson
Check Engine Light
Check engine light will also go on if there is any problem with the EGR valve's operation.
Mine had a leaky vacumn line going to it that kept it from operating, so the light went on. Fixed the vacumn leak and the light went off.
Old Aug 21, 2002 | 01:43 AM
rrcox1's Avatar
rrcox1
Check Engine Light
I have a 91 and it does the same thing, I did find out that ford has a recall on the check engine light, I am taking mine in on friday and will let you know
Old Aug 21, 2002 | 04:46 AM
FIANO's Avatar
FIANO
Check Engine Light
swick73
Jun 13, 2011 06:26 AM
-=Pit=-
May 19, 2011 09:30 AM
paultfh
2004 - 2008 F150
Dec 2, 2009 03:00 PM
krewat
Modular V8 (4.6L, 5.4L)
13
Nov 7, 2009 07:03 PM
Lowglow
1997 - 2003 F150
Feb 7, 2007 08:51 PM
