coolant flow
Old Aug 15, 2002 | 04:14 PM
95f1504x4's Avatar
95f1504x4
coolant flow
Old Aug 16, 2002 | 04:36 PM
vkaro45's Avatar
vkaro45
coolant flow
I've been having trouble with my van. See this link [www.ford-trucks.com/dcforum/DCForumID39/5151.html] The gauge shows in the middle of the temp. range but with the radiator cap off there is little to no flow of coolant across the radiator even with someone holding the gas pedal down. Shouldn't you be able to see the water pump circulating the coolant through the radiator? Could the thermostat be sticking? Or is this normal? Everything I have broke down at the same time.
Thanks
Rodger
