monster electric fan
Old Jul 3, 2005 | 02:44 PM
tibbetts77's Avatar
tibbetts77
I have a chance to get an unused universal mount flex a lite monster e fan. it will be going on a 95 f250 5.8. it is thermostaticly controlled with the ac relay, but it does not have variable speed control. Should I bother with this older model or should I just spend the cash and buy the newest model with the VSC? Thanks.
Old Jul 3, 2005 | 07:36 PM
chrono4's Avatar
chrono4
well wats the reason for doing this? iv heard bad things about the universal units, and you have to kinda rig them on there.
Old Jul 3, 2005 | 11:06 PM
Blurry94's Avatar
Blurry94
Universal mounts aren't all that difficult to install.
The thing you might want to look at is the CFM rating and your application.
Old Jul 4, 2005 | 07:38 AM
tibbetts77's Avatar
tibbetts77
my reason for doing this is install is to hopefully gain some gas milage out of it.
the 260 model is dual 14" rated at 5200 cfm, as far as I know it is the same as the newer 290 model without the variable speed control.
flex a lite does offer the VSC unit seperately, has anyone put this on an existing fan? was it a pain? a better question might be if I actualy need the variable speed at all? any info is appreciated. thanks
Old Jul 4, 2005 | 10:15 AM
Blurry94's Avatar
Blurry94
I use the VSC on my 13.5" dual puller (FAL-295) and it works great. It slowly ramps the speed up so there isn't as much strain on your electrical system. It also doesn't run at 100% if it doesn't have to. The 295's I run can usually cool the motor/radiator down at only 60% speed. If you do decide to use the VSC then i would recommend ditching the little fuse holder they give you, and go with a good 30amp automotive circuit breaker instead. The fuse holders have been known to cause fires under the hood.
Old Jul 4, 2005 | 02:33 PM
tibbetts77's Avatar
tibbetts77
well I will have to look into buying the VSC unit for this fan then, no sense running her at full bore if it doesnt need to. thanks for the help
Old Jul 5, 2005 | 07:58 AM
tibbetts77's Avatar
tibbetts77
the variable speed unit through jegs is 90 bucks..... woweee, maybe not!
I will probably look for a fan with the unit already on.
Old Jul 5, 2005 | 08:30 AM
5_labsownus's Avatar
5_labsownus
Ditto what Blurry94 said, I also have the 295 on my I-6 and love it.
P.S. If you get the fan a a real good price, you can buy the VSC from Flex-a-lite or a dealer for about $75.00 and add it to the fan.
Old Jul 5, 2005 | 05:07 PM
Blurry94's Avatar
Blurry94
Just checked Summit and they have the FAL 298 kits (look to be the same as 295's) for $299.
