self test code result
Old Jul 2, 2005 | 11:40 AM
southsidej's Avatar
southsidej
Question self test code result
Just did a self test on codes but not sure what code means after translating it..Light flashed twice, pause,light flashed once,pause, repeated twice and stopped. If I translated right and checked KOER chart it says "ECT out of self test range 0.3 to 3.7 volts". Meaning?
Old Jul 2, 2005 | 12:25 PM
MemOrex's Avatar
MemOrex
The engine must me at operating temp. for the ECT to pass the test.
Old Jul 2, 2005 | 12:53 PM
MustangGT221's Avatar
MustangGT221
For the KOEO test, it must be between 50-180 degrees, for the KOER test it must be at full operating temp of 180-200 degrees.
Say you get code 21....it'll do this...
flash (2 sec) flash (2 sec) (4 sec gap) flash........repeat....
Old Jul 2, 2005 | 01:40 PM
southsidej's Avatar
southsidej
Ok! Warmed up truck to operating temp. Now getting code Map sensor/BP out of test range. Getting close but, what gives with that reading?
Old Jul 2, 2005 | 02:42 PM
pfogle's Avatar
pfogle
The MAP sensor it either not working, or you have a vacuum leak.. Also are you sure you're reading the right flashes? There will be a series of flashes (3 for a 6 cyl, 4 for an 8 cyl, and 5 for the diesel, then a single "goose" flash which tells you to floor it, mash the brake, turn the wheel, and then hit the OD button. If you do all this then it will spit out trouble codes.
Old Jul 2, 2005 | 03:06 PM
southsidej's Avatar
southsidej
Just tested again and getting a series of 2 flashhes and then a pause and two more, pause and so on. after long pause a series of single flashes with a short pause in between, then stops. My truck is an 8 cyl. I am only using the KOEO as truck won't run long enough to get KOER.
Old Jul 2, 2005 | 03:39 PM
MustangGT221
It doesn't sound like there is a problem in the way you are running the test. I assume you ground the STI wire, and turned the key on and it's shooting codes at you, which means you're in the KOEO test. It just sounds like you're unfamiliar with the way they're suppose to flash.
Fordfuelinjection.com has a good explanation of how the flashes occur. Check that site out.
Old Jul 2, 2005 | 04:00 PM
southsidej's Avatar
southsidej
Yes ,I am unfamiliar. My first time." Ford Virgin Here".lol But,I am following step by step instructions from fordfuelinjection. As I said earlier, when the test begins, CE light flashes 2ce,short pause,2ce more,short pause,and goes for 4 cycles then a long pause, About 10 seconds then fashes 1ce,pause,again 1ce and so on cycling 5 times and test stops.I probably am reading wrong but still trying and not going to quit till I get it right.You guys are all giving me good info. Many thanks
