Its not cool
Old Jul 4, 2005 | 03:03 AM
jeff63's Avatar
jeff63
Its not cool
I have a 93 F-250 with the 7.3L diesel (non-turbo). The A/C is not working and the vent blows partly warm air even at the coolest setting. The A/C clutch does not engage and there is no voltage present at the compressor connector when I turn the A/C on. When I jumper 12 volts to the compressor it engages but the system does not put out any cool air. Is this as simple as needing a charge? Is there a low pressure switch in the system which prevents the compressor from running with low/no freon in the system?
Great truck so far (got a great deal when I bought it about 3 months ago). Hope to install a Banks sidewinder in the next year or two.
Jeff
Old Jul 4, 2005 | 05:50 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 4, 2005 | 07:34 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes, there is a low pressure switch, and yes, you need a recharge. but before you recharge it, you should run a vacuume test on it to see if there is a leak so you do not waste the freon
Old Jul 4, 2005 | 11:07 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
if it's similar to my F-150's cooling system, it only took 1 pound of R-134a refrigerant to charge the thing. If you are buying stuff or paying for a vacuum test, waste 10 bucks on the one pound of refrigerant. might be cheaper.
Ryan
Old Jul 4, 2005 | 12:08 PM
jeff63's Avatar
jeff63
Thanks for the quick reply. I will look into vacuum test/recharge. Jeff
Old Jul 4, 2005 | 12:10 PM
jeff63's Avatar
jeff63
Thanks Ryan. I like the idea of recharging to see if that works but its the old R-12 system. I've heard that stuff is pretty expensive. May be worth installing R-134 conversion.
Jeff
Old Jul 4, 2005 | 04:20 PM
green 1969 f100's Avatar
green 1969 f100
If you can find it in your area there is a drop in replacement for R12 that allows you to top off your existing system with no modifications. One way you can check for leaks is to apply a soapy water solution to all of the fittings and connections. You may find a loose schrader valve. Don't worry about pulling a vacuum on the system unless you evacuate it to make repairs.
If you are unsure of your ability,check with a reputable repair shop.
AggieOutlaw
May 19, 2015 02:26 PM
jeff gammon
Aug 4, 2009 11:56 PM
Jermafenser
Jul 13, 2009 11:33 PM
azcactus
May 24, 2009 12:00 PM
Aerocook
Aerostar
17
Jul 10, 2008 09:58 AM
