6.2L V8 Discuss the 6.2L V8
2011 Super Duty tranny problems
Old Jun 2, 2011 | 01:20 PM
  #271
2000silverbullet's Avatar
2000silverbullet
Had mine applied this morning (although it took them 2.5 hours to do an oil change, tire rotation, trans update..argh.)... I wanted to watch to make sure that specific tsb was applied but the service mgr knew all about it so I felt confident it was done. I forgot to ask them to drop the TPMS threshold but I'll bug them about it when I go back for the moonroof glass replacement. I know something was altered because the Android program (Torque) on my Xoom had a calibration ID of BRBL2A3.H32 and now it just says unknown.
Anyways, shifting feels much smoother and I was in stop and go traffic on the way into work for about 45-60 mins after it was applied. I think I've been hyper sensitive to the shifting patterns lately since I knew the update was coming, and now that it's applied, it seems much more improved than the previous program. Upshifts are smooth from 1-6 and I didn't seem to have the lurching that would occur when the truck was downshifting as I was coming to a stop.
Tomorrow morning I'll be able to better verify if the 2-3 shift issue is still present.
So far so good. I hope this fixes jeepman and racetec's trans issues.
Old Jun 2, 2011 | 01:29 PM
  #272
kmonty2's Avatar
kmonty2
How low are you running your tires?
Old Jun 2, 2011 | 01:37 PM
  #273
2000silverbullet
Right now I have them at 65 in the rear and 70 in the front. I'd like to go for a lower psi on the rear tires when empty, no need to that high of pressure when empty... I saw on the '12 ordering guide you can order the F-350 SRW's sans TPMS.
Old Jun 2, 2011 | 01:51 PM
  #274
kmonty2's Avatar
kmonty2
Will that just give you a better and smother ride? Can't see it helping with MPG through.
Old Jun 2, 2011 | 03:39 PM
  #275
Byram's Avatar
Byram
Mine seems to shift a lot better.. I was hauling a trailer (about 12K) so I was on the highway in T/H so could not tell much on the regular shifts.. I will report more later...
Old Jun 2, 2011 | 05:07 PM
  #276
2000silverbullet
It's worth it to me to air down a bit to have a softer ride. The roads out here in PA suck so driving around with nothing in the back can be jarring at times. Plus I hate these Michelins, 3500 miles and the fronts are already cupping. Dealer rotated for free for me today.
Old Jun 2, 2011 | 05:29 PM
  #277
Super08's Avatar
Super08
The sans TPMS is for fleet orders only though. Doesn't matter as the 2011 and 2012 trucks can easily have the alarm pressure set to what you want at the dealership with the Ford IDS. They have made it very simple to adjust unlike the 2008-2010 trucks. I too would love to do away with it as well though. I have a 2nd set of rims/tires I run in the winter so I end up with the light on it the dash all winter.
Old Jun 2, 2011 | 08:29 PM
  #278
2000silverbullet
I don't expect to catch any flack from my dealer, just forgot to ask. Will save it for when I drop it off for the glass replacement.
Old Jun 6, 2011 | 10:39 AM
  #279
Byram's Avatar
Byram
More on the update:
Got the TSB 11-5-19 Plus 2 solenoids on 6/1/11
Fp# BC3Z-7G383-L
Fp# BC3Z-7G383-N
also called for Fp# BC3Z-7G383-M Which is backordered & If I have problems they will install it later if I request...
Also 13 Qts XT-10-QLVC (Mercon LV)
So far Firmer, good shifts & to me it feels like I am staying in 1st a little longer (which I like)...
I have a place/time that I can easily replicate the 2-3 shift issue and I tried it last night & it didn't happen... I will test this further in the days to come...
I have put about 350 miles on since this "reflash"... I keep all my fuel purchases/mileage in a spreadsheet so I should be able to notice any fuel consumption changes in the future - My first tank I was pulling a trailer, so I cannot derive much from that tank - but I will post again in the future if I see any kind of change...
Old Jun 6, 2011 | 11:33 AM
  #280
Super08's Avatar
Super08
Awesome news. It sounds like they have found the fix.
Old Jun 6, 2011 | 11:53 AM
  #281
kmonty2's Avatar
kmonty2
Byram, when was your truck built? How long did they have the truck for? And did they say how long it takes to do the flash?
Old Jun 6, 2011 | 12:09 PM
  #282
Byram's Avatar
Byram
They had my truck overnight - they pulled the trans pan to get the proper solenoids to replace - ordered them & got in at 10AM the next day - got them replaced, flashed, & test drove & called me at 2PM..
I have a extended warranty that paid for most of a rent F-150....
Edit _Built 5/10/10
Old Jun 6, 2011 | 01:29 PM
  #283
2000silverbullet
Took my dealer 2.5 hours to do the update, change the oil, and rotate the tires. I've got about 200 miles on mine, not one 2-3 shift issue. I really like the way it's shifting now, like Byram said, it's holding the gears a little longer. FWIW - my build date was 12/8.
Mine's going back soon though, I just found brake fluid (slowly) dripping off my brake pedal (and onto my Husky liner)....
Old Jun 6, 2011 | 02:31 PM
  #284
kmonty2's Avatar
kmonty2
Good to know, so mine is new enough to not need the solenoids, just the flash. Built on 2-11-11
Old Jun 6, 2011 | 09:20 PM
  #285
gallgood's Avatar
gallgood
I notice some hard shifts occasionally but have not had it checked out yet. Fear it might turn into something serious later.
