6.2L V8 Discuss the 6.2L V8
2011 Super Duty tranny problems
Old Jun 22, 2011 | 05:58 AM
  #316
coonman111's Avatar
coonman111
What is it that the solenoids do.
Old Jun 22, 2011 | 07:18 AM
  #317
Byram's Avatar
Byram
I'm not a trans guy but on my tractors solenoids open & close valves in the the hydraulic system - so I would think the trans solenoids would do something like that.... Maybe someone like Mark K will come along & give us the real answer...
Old Jun 23, 2011 | 10:16 AM
  #318
Menghi08LT's Avatar
Menghi08LT
Well I have no records of them even touching solenoids on the transmission... nor did the coordinator mention it.. it did do the slip last night after not being driven all day too. Anyone have the TSB number on the update/solenoids?
Old Jun 23, 2011 | 10:22 AM
  #319
2000silverbullet's Avatar
2000silverbullet
It's part of the same trans update TSB. If the truck was built before a certain date (can't remember, Nov 2010 or something), the solenoids get replaced. If it was built after that, the replacement isn't necessary.
Edit - info is back a page in this post:
https://www.ford-trucks.com/forums/9...l#post10463482
Old Jun 24, 2011 | 07:04 AM
  #320
Menghi08LT's Avatar
Menghi08LT
Thanks, mine was built in March '10, so I guess it's time to call the dealer back for the THIRD time since now it does it between 4-5 and on upshifts 2-3.. and the ticking noise from the other post is getting worse to the point I feel like I bought a 7.3 TD.
Old Jun 24, 2011 | 09:31 AM
  #321
2000silverbullet
It might be time to find a new dealer if they can't follow 3 steps:
SERVICE PROCEDURE
1. Inspect vehicle build date.
a. If vehicle build date is on or before 11/19/2010, proceed to Step 2.
b. If vehicle build date is between 11/20/2010 and 4/11/2011, solenoid replacement is not necessary, proceed to Step 3.
2. Replace the three normally high solenoids. Refer to the Workshop Manual (WSM), Section 307-01B. Proceed to Step 3.
a. Remove solenoids in-vehicle, identify the service band required for LPC, C35R/SSB, C456/SSE solenoids. Removal of the control is not required.
3. Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 72.04 and higher or 73.01 and higher.
Old Jun 24, 2011 | 06:49 PM
  #322
loganworks's Avatar
loganworks
My truck was built August 2010 and they are going to replace the solenoids. The problem is getting the parts. I have been waiting for a month so far and the dealer still has no idea when they will come in. I have to get my oil changed but would like to combine the trip to the dealer with the TSB work because it's a 1 hr drive to get there and means taking a day from work. Has anyone else been waiting for parts and how long?
Old Jun 26, 2011 | 08:00 AM
  #323
Menghi08LT's Avatar
Menghi08LT
I finally bit the bullet and drove back to the dealer with a print out of what 2000silverbullet posted. They looked the TSB up again, and the service coordinator (not the one I've been dealing with) said "hm. It's been superseded". Made a drop-off appointment Monday, they will do a road test with it Tuesday and do the updated TSB, as well as drive it before I get it back with the computer hooked up to it. The dealer is also providing me with a rental car, probably a Hyundia or something... Hopefully it's at least a Fusion/Impala.
Old Jun 26, 2011 | 08:49 AM
  #324
seatowjoe's Avatar
seatowjoe
Which dealer are you using? I am getting ready to pull the trigger on a 2012, and I also live in Waterford, CT.
Old Jun 26, 2011 | 10:18 AM
  #325
2000silverbullet
It was superseded by TSB 11-06-11. Nothing changed with the procedure though, just the wording in the title and issue statement.
Old Jun 26, 2011 | 01:54 PM
  #326
Menghi08LT's Avatar
Menghi08LT
They were still looking at the TSB that does not mention the solenoids.
I went to Whaling City. They got me a really good deal on the truck, I'm happy with it but I've been at a battle about this issue... Just don't go to Plaza One
Old Jun 26, 2011 | 05:18 PM
  #327
coobie's Avatar
coobie
My dealer in michigan told me the same thing(superseded TSB)I cannot take my truck in until july 13
Old Jun 26, 2011 | 06:09 PM
  #328
Menghi08LT's Avatar
Menghi08LT
The worst part was when I called to make that initial appointment prior to this one, I told them there was a new TSB out on it since the last time I had the truck in...
Old Jun 26, 2011 | 08:13 PM
  #329
jeepman_79's Avatar
jeepman_79
Still waiting for an appointment
My dealer said they would notify me when the parts come in and when they have a loaner car for me I've been waiting 3 weeks....
Old Jun 27, 2011 | 04:16 PM
  #330
Menghi08LT's Avatar
Menghi08LT
They called me today saying the solenoid comes in at around 1pm tomorrow and it should be done by the time the service department closes.
