6.2L V8 Discuss the 6.2L V8
2011 Super Duty tranny problems
Old Jun 7, 2011 | 07:44 AM
  #286
milkman-06's Avatar
milkman-06
I have noticed a harsh 2-3 shift 3 times since we got the truck on the 2nd. All have occurred when taking off forward after the truck has been at rest overnight. Yesterday, I had to turn the truck around before I left. I ended up backing the truck in a 3 point turn and then backing up more for a last word with my wife before I took off. I backed in 2 separate maneuvers about 50 feet. I had no harsh shift. I will have to do this more times to see if a trend occurs.
Best regards,
Russ
Old Jun 7, 2011 | 08:55 AM
  #287
2000silverbullet's Avatar
2000silverbullet
Does yours have the latest flash on it?
Old Jun 7, 2011 | 09:57 AM
  #288
milkman-06's Avatar
milkman-06
It should, build date, I think 18 May. It does get good mileage, and smooth shifts.
Best regards,
Russ
Old Jun 7, 2011 | 10:40 AM
  #289
2000silverbullet
Gotcha.. I wonder if the fact that the torque converter locks up in 3rd has anything to do with it.
Admittedly, I don't know enough about transmissions to know if the harsher shift from 2-3 is due to the torque converter or not. I can say it's been nice not having to worry about getting on the gas after the truck's been sitting. Haven't been able to reproduce it yet and my trucks been sitting for days at a time when I've tried. It's been nice out so the XRL is gettin' some miles on it, not to mention I'm enjoying the 45mpg I get on it.
Old Jun 8, 2011 | 08:25 AM
  #290
milkman-06's Avatar
milkman-06
It sounds logical, however I have no expertise on transmissions, so I don't know.
Yesterday, when I backed up with cold truck, I only backed up 20 feet and the 2-3 shift was in between harsh and soft. More testing to come.
Best regards,
Russ
Old Jun 9, 2011 | 01:22 PM
  #291
loganworks's Avatar
loganworks
Well I think it is finely time to jump in and have the latest TSB applied. My trick build date was 8/30/10 and they will be replacing the 3 solenoids and shift up-dates on the 15th. I have not had serious problems with 2-3 shifting but it does happen when you least expect it. I had one incident when towing in TH when it did it and almost caused an accident. From others experiences this hopefully will take care of the problem.
Old Jun 9, 2011 | 02:49 PM
  #292
2000silverbullet
Keep us posted. Mine's still running good since the update, not one hiccup with the shifting since I had it applied.
Old Jun 9, 2011 | 03:14 PM
  #293
Byram's Avatar
Byram
Mine also... Tried to make it happen a couple of times & it wouldn't...
I still like the way it shifts.....since the flash..
Old Jun 9, 2011 | 07:41 PM
  #294
loganworks's Avatar
loganworks
Its good to hear that you have both been trouble free since the reflash. Have you noticed any difference in your gas milage like some have?
Old Jun 13, 2011 | 07:44 PM
  #295
Jhonson's Avatar
Jhonson
when was this latest re-flash out. I had mine done in early Feb and it still shifts funny.
Old Jun 13, 2011 | 08:00 PM
  #296
Super08's Avatar
Super08
About two weeks ago. Depending on your build date you may need some solenoids as well.
Old Jun 14, 2011 | 02:42 PM
  #297
loganworks's Avatar
loganworks
Well I just received a call from my Ford dealer and they have to reschedule the TSB work on my trans. They said that the solenoids are on back-order and that they don't know how long it will be before they get them. They had ordered them over a week ago to have them when I came in and checked on them today. There is still no ship date for the parts. You would think that Ford when issuing a TSB for the replacement of these would make sure that they would be in stock and ready to ship. NOW I need to try to reschedule some work for tomorrow so I won' be sitting on my #### and loose a days pay for nothing.
Old Jun 14, 2011 | 03:27 PM
  #298
chipwill113's Avatar
chipwill113
Still having problems
Its going on 9 month I have had the latest flash, dealer even put the recorder on the computer and still no fix. Talk to Ford Rep several times, a waste. They Have No Answers
Old Jun 14, 2011 | 09:45 PM
  #299
Super08's Avatar
Super08
I put a little over 100 miles on my new truck today and so far it is shifting smooth as silk. I am going easy on it for now. See what happens when it gets broke in a little and I push it some.
Old Jun 15, 2011 | 05:16 AM
  #300
coonman111's Avatar
coonman111
Would the reflash work if the solenoids were not changed.
