No more tuner
Old Jan 21, 2010 | 05:08 PM
  #196
Stewart_H's Avatar
Stewart_H
Canadian Bacon (ham) and Pineapple.
MMmmmmm GOOD!
I don't care who you are or what graphs you post, that there is the BEST!!
Stewart
PS - For Jim...
Old Jan 21, 2010 | 05:09 PM
  #197
PwerStroke99's Avatar
PwerStroke99
MMmmmmm GOOD!
Stewart
PS - For Jim...
HIJACK!!!!!!
Old Jan 21, 2010 | 05:11 PM
  #198
superduty4x4's Avatar
superduty4x4
Originally Posted by PwerStroke99
Stewart, this is the exact same way i feel, i could not have said it any better myself. And myself, like u, will acknowledge that there are other tuners out there and recommend them too, You have to pick the flavor you think u will like and go with it.
And i disagree with one thing.........
MeatLovers Pizza is best!!!!!
Meatlovers FTW!
Old Jan 21, 2010 | 05:30 PM
  #199
CampSpringsJohn's Avatar
CampSpringsJohn
MMmmmmm GOOD!
Stewart
PS - For Jim...
You DON'T FRUIT THE PIZZA!!!! Just like beer, you don't fruit the beer.
Just kidding guys.
Meat lovers is the best though,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old Jan 21, 2010 | 05:53 PM
  #200
LS1_SE7EN's Avatar
LS1_SE7EN
Originally Posted by DP-Tuner
Sean,
Thank you for asking this. I was hoping someone would. I think you have helped me prove my point.
At what temps do you want to know the timing? -36*C or 0*C or 95*C. Under what condition do you want to know your timing: ICP pressures, RPM, Air temp, what is the engine compression, what CPS, what IDM, what injector, what alititude and how much engine load....
There are many varibles to take into account when factoring timing. This is why you can only meassure this in the cylinder to get the TRUE timing in EACH truck. ALL of the variables MUST be taken into account.
All of the timing data I acquired was from a running truck with high speed test equipment. The 26* of timing noted was in the 80E at WOT (around 2500 rpm's.) Oil in the pan was at 80*F.
Jody
Thanks again for the info.
So 26* BTDC is the answer (for this particular truck). That seems like a very reasonable number.
I understand there are many variables. This causes a somewhat wide range of timing numbers depending on load, temp, etc, etc, etc. Keep in mind I am fairly new to diesels. The same basic principles should still hold true. Too much timing and it goes boom. This is especially true for a turbo charged high compression engine (i.e. turbo diesel). If this engine was under significant load and saw 45* BTDC (in any variable condition), I'm sure it wouldn't last very long. By average V8, I mean no advanced modifications for strength or anything built specifically to take serious abuse. Like I said, I am fairly new to diesel engines. Please correct me if 45* of timing is the norm.
Don't get me wrong. I am not attacking Jody at DP or anything of the sort. I just like to know how stuff works. I don't need any super secret patented details or anything.
I wouldn't think the timing should be anywhere near 45* BTDC if the engine is under enough load to build boost. This includes all variable ranges besides engine load and timing.
Old Jan 21, 2010 | 06:34 PM
  #201
CSIPSD's Avatar
CSIPSD
Someone mentioned blind faith in Jody. While I wouldn't necessarily classify it as blind faith, it is faith none-the-less. And it's no more so than found in the average customer for any of the other aforementioned tuners.
When Jody live tuned me, I told him what I wanted, and I have FAITH and TRUST in him to tune the way I asked. Do I have the equipment or knowledge to check to see if he's done that? Nope. But I trust him, so I believe he's done the tunes to my desires. That's not blind faith, because I know I'm pushing my truck. But it is trust. Trust Jody has earned.
Why should any of us who trust in our tuners be faulted for that?
I had faith in him too. I went from a tuner that had worked for me for 5 years because I thought I was doing the right thing.
I had FAITH in the fact that my PMR/Meth tunes were the safest I could run on the market. I was wrong.
Pizza is great, but if pizza hut is telling you they use real cheese, but sticking out of the dumpster on the way out you see a box of procced cheese spread are you going to go back and ask a few questions, or just assume the Izzie's Pizza from down the street planted it there?
Once the heads came off I started getting worried, then the cracked pistons, then the cracked block, then the cracked heads... All in 30k...
Did not have any of those issues with the old motor, running the same mods, with up to 70% meth in testing... All on PMR's.
The long list of DP tuned trucks popping at 400-450hp also opened my eyes, then looking at the other tuners pushing 550-600-700hp on stock bottom ends without the issues others were running?
Look at the graphs, look at the data... and add it up.
Old Jan 21, 2010 | 06:52 PM
  #202
twags6's Avatar
twags6
This is the kind of information I've been looking for.
Would I be right in thinking that a lot of the arguing about the issues with DP is centered around timing?
Old Jan 21, 2010 | 07:41 PM
  #203
CSIPSD's Avatar
CSIPSD
How about u send me your Swamps Chip so we can do some Data Logging on it and compare it to what we have?
Sure, What one do you want?
I have a Swamps chip, an Elite chip and a Swamps chip with PMT Split tuning on it? I am not quite sure what you want to see with data logging, but if you want to, knock yourself out!!!
Here is something else to look at. Look at these two pictures and tell me what one you think would be better for the truck... Then I will tell you whos tunes are on each one...
Old Jan 21, 2010 | 07:58 PM
  #204
parkland's Avatar
parkland
I think the bottom image represents "going easier" on the injectors, however the top might be part of the conditions part of creating a sharper, cleaner burn.
This ends up being personal preference / intent of the chip itself.
On a side note, remember that a weak point on these engines is the time it takes to deliver the fuel, creating prolonged stress on the internals during ignition....
Whats better: quick powerful injection; or longer less powerful injection?
Unless you happen to work at ford R&D with an unlimited budget, you might never know.
Old Jan 21, 2010 | 08:03 PM
  #205
Orezona's Avatar
Orezona
they are 2k and some miles apart?
Old Jan 21, 2010 | 08:09 PM
  #206
PwerStroke99
Hell Just send me your Swamps chip, so i can send it off to Bill and have him look at it, and give us some numbers. Not your Elite Chip, not your Swamps with Splits tuning, your SWAMPS chip like i asked.
Old Jan 21, 2010 | 08:14 PM
  #207
CSIPSD's Avatar
CSIPSD
Sorry... I have alot of pictures... Here is the one on the same day...
Old Jan 21, 2010 | 08:17 PM
  #208
CSIPSD's Avatar
CSIPSD
I was just trying to offer everything I could to you... If you have something to say then say it...
I will send both the Elite and Swamps chips to Bill with in the next few weeks, and pay to have both checked out... Now you send yours as well, just so we are all working on the same court.
I'll still pay for yours and Gregs... I am sure you guys dont feel like you have anything to hide do you?
Old Jan 21, 2010 | 08:19 PM
  #209
Orezona's Avatar
Orezona
Looking at your Sig., your truck is rocking with no problems
For comparison, you might just spend a few bills on a blank TS chip and pick Matt, TW or PHP for chits and grins...I will probably be picking up an extra chip soon cause I didn't realize the restrictions of receiving others tunes when I bought my burner. Maybe we can work something out with you sending MY blank chip to get burned for your mods? You will have to pick up the $40 or so for the rotary **** if you don't already have one
I offer this not because I doubt your tunes, but because I think it would be cool to see what you think. (i.e. free experiment ) JUST KIDDING ON THE LAST
  #210
PwerStroke99
I dont have anythign to hide, but i cant afford to be driving my truck around without my chip. So it isnt happening. I dont need u to pay for me to send my chip off to Bill, im big enuf to do that myself.
