It's okay. We dont expect everyone to like how I tune. All we ask of you guys is that we are given the opportunity to make it right. Yes, then if I can't satisfy their tuning needs then by all means try and find someone who can.
I've been working on my new tuning software for 4 months. It's killer and it has allowed me to find so many things now that I've tried to find in the past. My next live tuning trip is Feb. 4 and I can't wait to use it on the guys there.
Jody
Jody, im looking forward to this in April, its gonna be a lot of fun.
Originally Posted by F350-6
That's the part that throws you? I'm still trying to figure out the quote below. Apparently Bill has figured out a way with his tuning to make a hand shaker shift like stock
You can't adjust temps, you can only adjust the timing. That is not the same thing.
You have not answered my question about the stock 7.3l calibrations.
Example: Diane Excursion is running at WOT 26* of timing in the 80hp Econo. That's at WOT. Her factory stock tune is 24* at WOT.
So you will know, the Stock Calibration TDE1 has 45* of timing in 1 of the EOT timing tables. There's 2 EOT timing tables.
So yes Joe I do modify the EOT timing tables because that is too much timing.
Due to our new tuning software capability I can see each adder, datalog the adders, see the Total SOI while driving and play it back later. To verify the data I also datalog, FDCS, CPM, CPS, Trans temp , EGT's, Boost, Coolant, Oil temp in the Pan, Oil Gally pressure and any of over 4000 parameters.
If that's not enough, I'll be glad to show you my graphs.
U obviously have NEVER been live tuned, because Jodys Live tuning Sessions DO NOT cost $800+
True... The first time is only $350... then you add injectors or a fuel system and its "recomended" that you get live tuned again for another $300 or so... Then you want the shifting changed so its another $300...
Then you blow your motor and you go with another tuner for $450 or so....
This is just nuts to have this feeling of entitlement to free re-tunes that wouldn't even be close to the same. You add sticks, fuel system and who knows what else and you expect someone to redo all the tunes for major modifications for free? I just can't see that. And if someone does do it, I'd actually wonder just how much effort is put in to it.
Joe,
We don't twist anyones arms to get live tuning. It is a sign up only event. If you want your mods dialed in, yes live tuning is better.
IIRC, I've never live tuned your truck.
Jody
__________________ Jody & Diane Tipton- DP-Tuner® FTE Legacy Sponsors since 2006 Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost, Get Tuned!828-221-0076 ext. 802 Become our Facebook Fan
