Sponsored by: Real Truck
Gas vs PSD
Old Sep 12, 2009 | 10:22 AM
  #1351
Broncoholic1's Avatar
Broncoholic1
Originally Posted by Izzy351
Never heard a dozer or cement truck sound like this:
http://www.youtube.com/watch?v=HBY6YCS-8T0
Yep sounds just like my D3LGP Little more clunk clunk clunk...
Like I said 7.3's are good 6.0 & 6.4 suck, good till they blow up.
Turbo's spool up & down plowing snow = bad for turbo = tires spin when it kicks in.
Old Sep 12, 2009 | 10:26 AM
  #1352
Izzy351's Avatar
Izzy351
Originally Posted by bill11012
My V10 is stock, 2v non PI. 3.73s and 4R100. I have towed up to 18,000 gross.
It is lacking on the low end, and with these gears I can not get the revs up to peak HP tell about 35mph. Once I have gotten up to that speed, I can keep up with traffic easily.
I tow 2-4 times a weak, most loads about 15k gross.
I have driven a 7.3, 2 V10s and a 5.4. All 98 or 99.
The 5.4 with an empty trailer was pathetic.
The 7.3 has a lot more at low rpm, but the V10 in the right rpm range pulls much harder.
I'm in the DFW area, Bill. Considering the quote in your sig, would you like to meet up and do some real-world comparisons? I'm being serious here -- not trying to be a smart-azz....
Old Sep 12, 2009 | 10:28 AM
  #1353
Izzy351's Avatar
Izzy351
///SNIP///
Got an audio clip of the D3LGP?
Old Sep 12, 2009 | 10:30 AM
  #1354
bill11012's Avatar
bill11012
Modular motor junkie
OK, I might be taking a tractor through there early next month.
Old Sep 12, 2009 | 10:32 AM
  #1355
Izzy351's Avatar
Izzy351
Shoot me a PM when you know. Is this a goose neck, fifth wheel, or standard trailer?
Old Sep 12, 2009 | 10:33 AM
  #1356
Broncoholic1
Not mine just like it tho...
Pretty loud Just like a PDS
http://www.youtube.com/watch?v=41U37g-GMpo
Old Sep 12, 2009 | 10:36 AM
  #1357
bill11012's Avatar
bill11012
2" bumper pull. I can not have a GK or 5th wheel, My V10 is in a E350 SD van.
Old Sep 12, 2009 | 11:11 AM
  #1358
jdadamsjr's Avatar
jdadamsjr
Joe, Am in the dfw area too...
Already asked and offered MANY times - but no takers
Wonder why ?
And love the cat footage - worried it was going to tip over there for a sec ! ! !
Wasn't sure how far they could lean safely.....
Witnessed a crane tip over at a construction site once.... BIG operator error there...
glad I was on the "correct" side !
Old Sep 12, 2009 | 11:42 AM
  #1359
bill11012's Avatar
bill11012
Wonder why ?
I do not want to compare my 265 HP 98 v10 to your 05 325 hp 6.0.
You need a 05- V10 to compare to.
Old Sep 12, 2009 | 12:10 PM
  #1360
KelVarnson's Avatar
KelVarnson
Uh-oh, better modify your sig line...
Old Sep 12, 2009 | 12:15 PM
  #1361
bill11012's Avatar
bill11012
I should make it " My V10 will out pull your stock 7.3 PSD any day of the week".
but I like it the way it is.
Old Sep 12, 2009 | 01:11 PM
  #1362
Izzy351's Avatar
Izzy351
Well then you don't want to meet me either. When you guys talk HP, y'all need to specify flywheel or rear wheel HP. The last time I dyno'ed, it was 311/681 at the rear wheels and I've changed a few things since then. I'm estimating 325 and closer to 700. For now.
Old Sep 12, 2009 | 01:16 PM
  #1363
Izzy351's Avatar
Izzy351
Since they are embedded, play both at the same time. They sound pretty different to me...
Old Sep 12, 2009 | 01:24 PM
  #1364
bill11012's Avatar
bill11012
wow, what mods have you done?
when i talk HP, I am talking about flywheel.
I have seen rear wheel dyno numbers for the first (97-99) V10s, they are about 198-204 RWHP depending on the truck and dyno.
Old Sep 12, 2009 | 01:27 PM
  #1365
agg_bagg's Avatar
agg_bagg
i run then for a living. they will slide before they tip usually. and you can get them to stay sideways on about a 50* to 60* degree slop depending on the dirt.
