Gas vs PSD
If you did do it that way, then the machine could translate the force on the rollers directly into an actual engine torque number.
On the other hand, if you were testing mods to the same vehicle, I suppose it would be a fine method for getting relative data.
He put those miles on his truck since August 2010. For that kind of savings, wouldn't you at least consider an EGR delete? Some states are more strict on emissions than others. Being he's running an F450, I doubt many DOT guys could figure out if the EGR has been disconnected or not. I don't know of a single one that will climb under your truck (an F450 or so) for an inspection. I just had one done last week.
as for considering an egr delete, i'd be considering the average life lost by the egr system on a diesel. . .its impossible to tell just how damaging the egr is to a diesel. . .but the motor oil life is cut in 1/2 (at least) by the egr, and turbo's get gunked up and destroyed by them. as the 6.blow guys know best, the egr causes nothin but headaches. the poor 6.0 is a venerable motor (with good mileage) once theyre studded, all the emissions equipment are gone, and the stock turbo is gone. but theyll never come back from their reputation at this point. . .
Stealth 316 - Formulas for 1/4 mile ET & mph vs. hp & wgt
^ the above link (there are countless) seems like a good all around description of the hp calculator (i know you like numbers). i think also, no1 is calculating theirs by hand anymore, but rather punching their numbers into a "calculator" like the ones on the internet. . .engineers and mathemeticians have refined the equation a bit over the years, so it seems, in order to compensate for some of the variables. but just like it says in the link, no matter what its still a guesstimate.
my point was, the calculation is what it is. there isnt much you can do to except outright lie on the input data to get a faulty number, and you basically take anyone elses agenda out of the equation.
My car is the perfect example of why.
It weighs 3670 lbs at the track.
12.16@111.78
Your "calculators" can't even agree on what HP it's making.
If I input MPH and weight, it says I'm making 418hp.
If I input E.T. and weight, it says I'm making 521hp.
So, which one is it?
JL
12.16@111.78
JL
using all of your above input variables, in this hp calc Horsepower Calculator from 1/4 mile ET and Trap Speed - DragTimes.com 397.58 at the fly is the result. . . sounds like you have a close-to-stock ls1 6 spd f-body
. . .w/ mild bolt ons at ~325 wheel (x1.15 = about 375 crank) and 3500lbs i ran a 12.6 @ 113. the calculator is pretty accurate. not precise, but accurate.
using all of your above input variables, in this hp calc Horsepower Calculator from 1/4 mile ET and Trap Speed - DragTimes.com 381.33 at the fly is the result. . . sounds like you have a close-to-stock ls1 6 spd f-body
. . .w/ mild bolt ons at ~325 wheel (x1.15 = about 375 crank) i ran a 12.6 @ 113. the calculator is pretty accurate. not precise, but accurate.It's an auto trans 4.6L N/A Thunderbird.
And when I plug the numbers in to the calculator you just linked, I get 401.74 hp.
JL
edit: just redid my calc's on your car. . .musta put in 111 vs 111.78 for your car, worked out to be the 398 i originally posted with 111, 111.78 yields your numbers.
The car has been on several dynos, at several different locations.
Mustang and Dynojet both.
The most it's ever put down on the rollers has been 270rwhp.
It's NOT losing 131 hp through the drivetrain.
JL
somethin is rotten in denmark. . . .is your gearing setup solely for drag racing (i.e. run across the line at redline in top gear)? also, if youre seein the same numbers on a mustang dyno AND a dynojet, somethin is wrong. . . .dynojet = inflat-o-meter.
By using values from other similar vehicles and powerplants, my estimate is approx 310rwhp. But still-I'm not losing nearly 100hp through the drivetrain.
That's the point. Those calculators are NOT as accurate as some people think they are. The 4200 rpm stall converter, 4.30 gears,etc all make a huge impact on those calculations, along with the fact that the converter is only unlocked for the launch in 1st, and locked for the remainder of the run. The car 60's in the area of 1.67-1.70, so a very good 60' for the weight and power output also skews the calculator.
No, I'm not seeing the same numbers on a Dynojet and Mustang. Dynojets are usually 10-15rwhp higher.
The car has a 4.30 gear in it, and crosses at 6500ish RPMs. But it's by no means a "track only" setup.
JL
JL
310 x 1.2 (20% drivetrain loss which is typical (and somewhat a generous estimate) for a large ford rear axle and any auto) = 372 BHP. 30 BHP is MUCH LESS than the 40 wheel that you, yourself, admit the "highest" dyno run basically underestimated (so im being nice and not using your low"er" values generated by other dyno's).
It only take a certain amount of hp to turn a gearset. Increasing the hp of the engine does NOT increase that amount of power lost through that gearset be it trans or rear axle.
I'm not gonna sit here and argue with you all day about it either. Those calculators are nothing more than "getting you on the target" accurate.
JL
JL
so if drivetrain loss isnt a percentage (obviously different setups would be a different amount of loss) then what is it? certainly you cant say an axle takes X amount of hp to turn (which would be true) and that's that. . . .because an axlesoaks a certain amount of power to accelerate. . .that bein said, the harder the acceleration, the more hp it takes to keep the axle accelerating. of course, it takes a certain X amount of power to turn an axle X amount of rpm (which doesnt account for acceleration). . .so if drivetrain loss isnt most accurately described as a percentage, what best describes it? ? ? you'd be teachin me somethin. . .
