Sponsored by: Real Truck
Gas vs PSD
Old Oct 22, 2010 | 03:05 PM
  #9091
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by exiled
Bill will beable to put his truck in 2nd and drive 0-65 never have to shift gears. Yea he'll start out slow, but tell me that aint wild.
Yea, thats one other nice thing about the V10. It has a very wide RPM range. It can pull anywhere from 1000 RPMs where its making 80% of its peak torque, all the way to the 4,600 RPM upshift. It will run to the 5,300 RPM limiter if I move the shifter to 2.
Old Oct 22, 2010 | 04:24 PM
  #9092
Kajtek1's Avatar
Kajtek1
Or he will not start at all. Just like already said several times, at certain load the engine will rev, but the truck will not move.
Old Oct 22, 2010 | 04:56 PM
  #9093
exiled's Avatar
exiled
Please understand I'm not calling you out. I'm trying to learn here. I've used a few calculators and plugged almost every possible combo into it. What I get w/ a gear of 2.20-2.82:1. That should cover your 2nd gear ratio. 27" -33" tire highth 3:73-4:30 rearend with 4600-5200 rpm I have speed range of 35-48mph. It just puzzles me how you can get 65 mph out of 2nd gear. I bet you won't drive in 2nd all day or pull for very long. I just tried to do it again and I noticed my transmission temp shot up to 190•. I think you burn your tranny up with to much of that going on. I'm going to video sometime this weekend.
My psd pulls in it whole range to. That's something else I don't really understand. Is how more rpms=better towing. Well I could if the situation was that my power was in a rpm range that I could obtain, but my power is in my range. Oh well I guess somethings aren't meant for me to understand
Old Oct 22, 2010 | 05:18 PM
  #9094
RUFFSTUFF's Avatar
RUFFSTUFF
Originally Posted by Lead Head
You can make up for that torque disadvantage by down shifting to another gear, or running lower rear end gears.
Here we go again.
Old Oct 22, 2010 | 05:36 PM
  #9095
driximus's Avatar
driximus
Originally Posted by RUFFSTUFF
Here we go again.
Yes its the circle of Life.
Old Oct 22, 2010 | 05:42 PM
  #9096
exiled's Avatar
exiled
Again as it turns out my truck is clearly different. I can start my truck in 2nd and get up to 40mph. I would think he could do the same, but then again he can drive 65 in 2nd so I don't know.
Hey Bill let me if you can start out in 2nd gear.
For that matter I can start out in 3rd. I do it a lot when I'm loaded in loose or slick ground. I can put enough power to the ground to get moving but enough to break traction.
Old Oct 22, 2010 | 06:59 PM
  #9097
RUFFSTUFF's Avatar
RUFFSTUFF
lol Werd
Old Oct 22, 2010 | 07:10 PM
  #9098
bill11012's Avatar
bill11012
I know.
Ok, this is why your numbers are coming up wrong.
My first gear is 2.70.
Second on the 4R100 is 1.54
third 1
forth 0.71 OD
Its hard on the tranny to start off in a higher gear like that, but going down the road at speed with the TC locked it should not make any more heat than in third.
I will see if I can get a vid from a stop until it winds out, locked in second.
With 3.73s and 31" tires, its not too wound out at 65.
Old Oct 22, 2010 | 07:11 PM
  #9099
Lead Head's Avatar
Lead Head
The 4R100 transmission has the following ratios: 2.74:1 1st, 1.54:1 2nd, 1:1 3rd, .71 4th.
1.51:1 2nd with 4.10:1 rear gears and 31" tall tires with a redline of 5300 yields a top speed of 77. It will probably shift at 4500-4700 RPM - around 65 MPH.
Originally Posted by tgreening
Ever wonder why diesels generally have taller gears than gassers? They dont NEED the higher rpms. That's why it's going to be in the higher gear. All this talk assumes the PSD will NEED to drop a gear at the same time the V10 does and this is simply not the case.
No one is saying the Diesel needs the higher RPMs, we're saying that the V10 indeed does need the higher RPMs, and has a high enough red line that it can utilize the gears of a transmission better at highway speeds.
Hmm indeed. How exactly are you managing to maintain the exact same rpm in the exact same gear at the exact same road speed, using two different rear end ratios?
Okay, the V10 with 4:10 gears will be at a higher RPM, but a difference of 500 RPM shouldn't drop off torque that much.
In your V10 4.10 scenario you're either doing 68 mph or about 5100 rpm. Take your pick. The V10 "might" still pull 3rd gear with 4.10s at 75mph, but I don't know how long I'd want to stay there. How about you? Especially since it falls flat on it's face right about there.
And assuming your numbers are correct, which is suspect. I'm looking at independent dyno charts of both engines that tell a different story.
V10 - 4700 rpm HP- 240 RW TQ-260 RW
6.4 - 3100 rpm HP- 250 RW TQ- 420 RW
The V10 is designed to run at that RPM all day long. It won't be pleasing to your ears or your wallet, but it will do it. That is only in an extreme case anyways that it will need to hold 3rd that long with a 5R110.
Different dyno brands produce different results, and even the same dynos from the same company can produce different results depending on the fudge-factor the dyno operator puts in. I personally think both those dyno results are a bit suspect, when you consider the average 09+ RAM 1500 Hemi (Rated at 407 lb-ft) typically dynos at around 300 RWTQ, I find it hard to believe a 457 lb-ft V10 only dynos at 260 RWTQ
Old Oct 22, 2010 | 07:28 PM
  #9100
Lead Head's Avatar
Lead Head
Double Post
Old Oct 22, 2010 | 08:44 PM
  #9101
Kajtek1's Avatar
Kajtek1
My 7.3l will pull the 10k truck on 5-th turning 900 rpm
When I bought the truck, took me a while to get the feeling of lousy transmission shifter. So several times I started on 4th gear. The engine clunked loud for couple of seconds but moved with no other problems.
Old Oct 22, 2010 | 10:38 PM
  #9102
exiled's Avatar
exiled
I know.
third 1
forth 0.71 OD
Aight then with the 1:54 ratio and 4:10 rear with 30" tires at 5200 rpm it came out to be 66 mph. I don't know about the heat issue and no way for me check it out cause my buddy only has the factory trans heat gauge.
Looking closer I see why them trucks are fast. I don't see the pulling power with those gears. Again something else for me to dig into. Lol.
Now I don't see the v10s with the TS tranny doing 65 mph in 2nd cause it has the same gearing as mine.
Old Oct 23, 2010 | 01:35 AM
  #9103
exiled's Avatar
exiled
When I run the numbers I come up with 66 mph top speed.
Old Oct 23, 2010 | 03:19 PM
  #9104
bill11012's Avatar
bill11012
I have 3.73s. I'll see if I can get a vid of my truck on the limiter in second.
Old Oct 23, 2010 | 04:34 PM
  #9105
Lead Head's Avatar
Lead Head
1.51 x 4.1 = 6.191 Reduction ratio
5300 RPM / 6.191 = 856 revolutions per minute of the tire.
31" diameter. 31 x Pi = 97.34" Circumference
856 revolutions/minute x 97.34 = 83323 inches/min. Divide by 12 = 6943 feet/min. Multiply by 60 minutes = 416615 feet/hr. Divide by 5280 = ~78 MPH.
