Sponsored by: Real Truck
Gas vs PSD
Old Aug 5, 2009 | 02:28 PM
  #901
HuntsDucks70's Avatar
HuntsDucks70
Originally Posted by mongo75
and you will never be able to spend equal amounts of money on both vehicles and be able to keep up with a diesel. That I bet my house on.
you make this so easy, So?
Old Aug 5, 2009 | 02:43 PM
  #902
HuntsDucks70
Originally Posted by mountaineer27
my 7.3 doesnt need to be a 5.5k rpms to sting mud. diesels are a low rpm motor. thats they way they work. your v10 needs the rpms to make power and sling mud. lets put it this way. have both trucks at 3.2k rpms and see who is slinging the mud. at 3.2k rpms im doing 75 down the freeway.
75mph at 3.2k, then you are just about topped out, i guess i will just keep on going all the way up to 5.5k and leave you sitting at 75mph!
Old Aug 5, 2009 | 02:56 PM
  #903
mountaineer27's Avatar
mountaineer27
you keep on wishin.
just about topped out huh, you must have owned my truck before me since you know so much about it. its weird, i dont even know what my truck tops out at yet. never had to top it out, all ive raced is ***** v10's.
and i dont need all those rpms to pull your truck out of the mud after you dig yourself in a hole from slinging all that mud haha. just good old fashioned power!
Old Aug 5, 2009 | 03:00 PM
  #904
Tom's Avatar
Tom
Why are we rehashing almost the EXACT same argument that's been beaten to death over the last 30 pages?
mountaineer27 seems to be a typical PSD guy who believes that because it's a diesel it's automatically better in every way. Not likely, but go ahead and keep stroking your ego.
And, for what it's worth, as we hashed out on or about page 26, horsepower can't lie. A STOCK 7.3 is really no match for a stock V10. Modded is obviously another story.
Old Aug 5, 2009 | 03:01 PM
  #905
dd6464's Avatar
dd6464
think of it as if you were turning the motor over by hand off the hermonic balancer. a quarter turn on the balance is a full rev of the piston.
sorry, but you don't have a clue how the 4 stroke internal combustion engine works. It takes two revolutions of the crankshaft to complete one combustion cycle. 4 strokes, 2 up and 2 down. Piston cycle is equal to crankshaft rotation. The camshaft makes one revolution for every 2 crankshaft revolutions.
Old Aug 5, 2009 | 03:03 PM
  #906
mountaineer27
and thats the only thing you v10 people have. paperwork. well comunism looked good on paper too but we all saw how that played out.
Old Aug 5, 2009 | 03:07 PM
  #907
jdadamsjr's Avatar
jdadamsjr
Hmmm.....
this is so much fun !!!!
Now we are slipping into the gearing comparisons again
Topped out @ 75 ???? I WANT some o dem drugs
3.73's in mine has been faster than I want to say ......
tires are the limiting factor to safety....
you are right I can't go 5.5k rpms, or nor do I have to as I'm waving bye-bye to you in my rear view
Stock we are limited to about 95 or so,
removing that limiter will allow me to runup to about 4250 rpms which puts the speedo WAY faster than it should go without speed rated tires....
Old Aug 5, 2009 | 03:08 PM
  #908
mountaineer27
congrats. did you read down a couple posts.
Old Aug 5, 2009 | 03:17 PM
  #909
grandaddy's66's Avatar
grandaddy's66
Originally Posted by jdadamsjr
if and buts and bench racing go hand in hand....
ZOMG!!! That's BEEYOOTEEFULL!!!!
I do give the v-10 one thing....
they are usually the engine in the "short-buses"
hardy har har! THAT'S the way to put water on the fire!
friggin hilarious!
Old Aug 5, 2009 | 03:22 PM
  #910
grandaddy's66
Originally Posted by QwkTrip
Part of the confusion, or ignorance as you call it, is that people are highly focused on peak numbers. Your statement is a good example of that confusion and the 5.4L (~300 Hp) vs. 7.3L (~230 Hp) is the perfect answer to that statement.
Driving a vehicle is dynamic. An engine isn't an on/off switch that goes from idle to peak torque and/or horsepower. You have to drive up through gears and run at all engine speeds. The engine that makes the most average power during the race wins. There is no way in hell that a 300 Hp 5.4L can out tow a stock 7.3L. Hook up a load and the 7.3L makes greater power most of the time, while the 5.4L makes greater power a little bit of the time. The heavier the load the greater the disparity. And don't give me some wild idea that you're going to put 8.xx gears in the rear axle. You want a tow rig not a rock crawler.
Now, if you don't believe me then please explain why a 400 Hp Honda Civic engine isn't a good choice for a heavy truck. We all know it is true... but WHY???
excellent post. This, boys and girls, is what I call a nollij post
Old Aug 5, 2009 | 03:25 PM
  #911
dd6464's Avatar
dd6464
of course not
Old Aug 5, 2009 | 03:26 PM
  #912
brian42's Avatar
brian42
Veteran: Navy
wow! an amazing observation there! you should really think before you write, the 6.4 only went for 3 years, THAT SHOULD HAVE TOLD YOU SOMETHING!!!! and you should know that the V10 is still offered by Ford, motorhome chassis.
Will it still sling mud at 5.5K RPMs though?
At 3.2k rpms im doing 75 down the freeway.
Are you running 5.88s in that thing??!!?!?! I'm at 2250 at 75mph. If you calculate it out you are looking out at topping out around 118mph at redline (3400rpm) for a stock 7.3L (3.73s and stock tires). I'm sure the 6.0s are even faster with the 5 speed Torqshift.
Old Aug 5, 2009 | 03:41 PM
  #913
Tom's Avatar
Tom
Holy crap, Mountaineer27! Look at my darn signature!
I have NEVER even so much as driven a V10 SD. I do, however, own a 2008 F250 4x4 with the 6.4L PSD. Do I really need to spell out what those three letters mean?
Old Aug 5, 2009 | 03:46 PM
  #914
jdadamsjr's Avatar
jdadamsjr
double post - giggling too hard
Old Aug 5, 2009 | 03:51 PM
  #915
jdadamsjr's Avatar
jdadamsjr
Now our bench racing is back to Top End
Thank you - I think I pulled a muscle giggling at that change of direction....
You guys run for political office ?
Admin - what's the next level after Post Fiend ?
joined here in Oct 2002 and think this thread has doubled my post count and laughter
hmmm, was just about to go looking for a net calculator to do just that -
but ----- that giggling got me
a 6 oh with redline @ 4250 and 3.73's with 16" tires SHOULD go past that....
It's pulling HARD at 100, but I won't go that fast on my tires....
and would thik aerodynamics would come WELL into play with my "shoe box"
