Sponsored by: Real Truck
Gas vs PSD
Old Aug 4, 2009 | 12:10 PM
  #856
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by Ace!
If I don't post again for a little while it's because I use my truck to line the bed with plastic, fill with water and drive bikini-clad hot chicks around town.
I call shotgun!!!!!
I'll even park my diesel (with an oil pan under it to catch all the leaking oil) and ride in a gasser for that!
Old Aug 4, 2009 | 02:03 PM
  #857
04redstroker's Avatar
04redstroker
my diesel isnt slow
Old Aug 4, 2009 | 02:12 PM
  #858
mountaineer27's Avatar
mountaineer27
if you had a psd with stacks you could have a hot tub. any you wouldnt need to put it in 4 low to pull that water around!
Old Aug 4, 2009 | 02:15 PM
  #859
Destroya's Avatar
Destroya
Someone found an actual purpose for stacks on a pickup truck!
Old Aug 4, 2009 | 02:21 PM
  #860
mountaineer27
there good for storing empty beer cans at a tailgate party too!
Old Aug 4, 2009 | 02:22 PM
  #861
Destroya's Avatar
Destroya
Post #44 is hilarious yet very much true......
LMFAO!!!!
Old Aug 4, 2009 | 04:28 PM
  #862
Tom's Avatar
Tom
Originally Posted by jdadamsjr
First you have to prove it here on the internet.....
but need some stout formuli - I only studied Chemucal Engahnerin in cullege - and do dat Systems Analysis on dem puters so i may not unnerstan
come on down - it's fun to play
I should have been more clear. My work truck is NOT a super duty, and does NOT have a PSD in it. Empty it weighs 33,000 lbs.
But if I get down there with my pickup, I'll be sure to send you a PM!
Unless you're still interested....
Old Aug 4, 2009 | 04:32 PM
  #863
jdadamsjr's Avatar
jdadamsjr
HA HA !
Ever seen an Ex do a wheelie ?!?!
still game if you can fit on on 1/8th mile !
Old Aug 4, 2009 | 04:54 PM
  #864
Tom's Avatar
Tom
Sounds good to me! Where are you gonna find 24K to hook to your Ex?
Old Aug 4, 2009 | 08:15 PM
  #865
QwkTrip's Avatar
QwkTrip
Originally Posted by Johnny Langton
Fuel is part of the equation-not the entire source for the power gain.
Pour all that fuel into the engine without adding air via MORE BOOST and see what happens. The same thing happens with force induction on a gasoline engine.
JL
You were wrong the first time and you're still wrong. Wanna go for a perfect three out of three? If you poor a bunch of fuel into a diesel then you get a bunch of power and a whole bunch of smoke. You can make things even better with a properly sized turbocharger, but it is not necessary.
The same thing does NOT happen to gasoline engines. You have to be extremely careful with the fuel-air ratio and that limits the amount of fuel you can inject. I've owned supercharged cars in the past and currently have a supercharged big block Chevy. Running lean is the death of a supercharged engine.
Old Aug 4, 2009 | 08:31 PM
  #866
QwkTrip's Avatar
QwkTrip
Originally Posted by alchymist
Did anyone notice that when the PSD VS V10 discussion stalled, the diesel crowd decided to beat up on the 5.4?
No, some fart came in and decided to put a stock small block V8 on par with a 7.3L. Then he got a beating.
If he said that a 3V 5.4L will out tow a 2V V10 do you think everybody would hug and sing Kumbaya? LOL! There would be cannibalism among the gassy clans.
Old Aug 4, 2009 | 08:52 PM
  #867
Johnny Langton's Avatar
Johnny Langton
So go ahead and pull the turbo off and see what happens when you've got all that smoke pouring out of it. Your theory says it'll still make alot of power without a turbo to add airflow to the equation. Prove me wrong-I'm waiting.
There's a real reason that there are very few to no N/A diesels left out there in on-road vehicles-they're a pig.
JL
Old Aug 4, 2009 | 09:08 PM
  #868
mountaineer27
JL
hate to say it but this gasser is right^. without more air ur just killing the power. choking the motor. for fuel to combust right you need the fuel to air ratio to be perfect. when you get black smoke thats all unburn full going out the exhause cuz there wasnt enough air for it to combust. thats why a turbo is so great. its put all the air you need plus some in the motor.
fire 1o1. = air+fuel+heat = fire take away any one and no fire
Old Aug 4, 2009 | 09:17 PM
  #869
QwkTrip's Avatar
QwkTrip
JL
Wow.... Your thought process darts around all over the place! I don't know what conversation you're having now, but it's not the one we left behind a few posts up.
Old Aug 4, 2009 | 09:20 PM
  #870
mountaineer27
supercharger is way diffrent that a turbo boss. and the problem with gassers and superchargers is the rpms. diesel are low rpms and can take that kinda compression in the cylinders. the supercharger runs off a cam or crank. if the pistons are turning at 6000 rpms then the crank is turn way faster boss. think of it as if you were turning the motor over by hand off the hermonic balancer. a quarter turn on the balance is a full rev of the piston.
