Sponsored by: Real Truck
Gas vs PSD
Old Aug 4, 2009 | 09:21 PM
  #871
Rush117's Avatar
Rush117
To sum up this thread:
1. V10 guys hate turbo's.
2. Diesel guys hate spark plugs.
3. Diesel costs more to maintain.
4. V10's consume gas like Bill Clinton consumes hookers.
5. The Germans made a diesel aircraft engine with 2 pistons per cylinder, which proves - nothing!
6. Lots of math has been done - a benchmark of bench racing.
7. Vans have smaller tires than pickups.
8. The 5.4L is....well...a 5.4.
9. Now we're talking about pulling turbo's off - again. Back to square one.
Did I miss anything?
Old Aug 4, 2009 | 09:24 PM
  #872
mountaineer27's Avatar
mountaineer27
we know all that^ just like to bicker at eachother
Old Aug 4, 2009 | 09:27 PM
  #873
Old93junk's Avatar
Old93junk
This thread, like herpes........continues on without end.
Old Aug 4, 2009 | 09:35 PM
  #874
Tom's Avatar
Tom
Originally Posted by mountaineer27
supercharger is way diffrent that a turbo boss. and the problem with gassers and superchargers is the rpms. diesel are low rpms and can take that kinda compression in the cylinders. the supercharger runs off a cam or crank. if the pistons are turning at 6000 rpms then the crank is turn way faster boss. think of it as if you were turning the motor over by hand off the hermonic balancer. a quarter turn on the balance is a full rev of the piston.
Um...not quite.
RPM = Revolutions Per Minute
A revolution is a complete 360 degree rotation of the crankshaft. If the tach says 6,000 RPMs, that's exactly how fast the crank is spinning.
And I think both of you guys are right.
Diesels are almost always running lean. Something about the diesel cycle makes that okay for a diesel, but NOT okay for a gasser. Which would be why most diesels are unthrottled. They don't need throttle plates, because you can adjust the power by adjusting how much fuel is delivered into the cylinders.
I believe many tuners have the capability of increasing boost, but the majority, at least on the 6.4s, work with the 41 PSI of boost that's available stock. There's more power to be made without increasing boost, but it's not done that way stock for emissions and efficiency purposes.
So yes, you can add power without adding ADDITIONAL boost(yes, Johnny you STILL need the turbo!), but I do know that there are tuners that increase boost pressures.
Everyone happy now?
  #875
QwkTrip's Avatar
QwkTrip
hate to say it but this gasser is right....
No, he thinks that a diesel tuner makes big power by increasing boost pressure and keeping the air-fuel ratio constant. He's doesn't understand how a diesel can increase power output just by adding fuel alone. Most the recent conversation is related to fueling as a power adder. But he's taken it way off course now.
Edit: Read Crazy's post. It's better than mine and I didn't see it before I posted.
Old Aug 4, 2009 | 09:37 PM
  #876
alchymist's Avatar
alchymist
"Mifflin Clay"
Only "I'll give up my V10 when they pry my cold dead hands....", Oh, wait, that's a different controversy. My bad.
A vote is like a rifle; Its usefulness depends on the character of the user.
Teddy Roosevelt
Old Aug 4, 2009 | 09:54 PM
  #877
QwkTrip's Avatar
QwkTrip
I'm not sure what is your point?
Diesel can run high compression and high cylinder pressure because it operates on auto-ignition. Diesels operate at low speed because the burn rate of diesel is slower than gasoline. A belt driven supercharger has a pulley drive ratio that should be sized for the engine. I have a roots blower. It is a positive displacement pump so it will supply proportionally correct air to my engine at all speeds. Turbos work on gasoline engines too and up to any speed the engine can handle.
Old Aug 4, 2009 | 10:38 PM
  #878
2001400ex's Avatar
2001400ex
I don't know, all this science makes my head hurt and means jack chit!
Fact's are:
1) the magazine article is a bogus comparison (weight difference and length of pull)
2) people are not comparing same vehicles
3) paper means nothing in the real world, there are so many other factors such as environmental conditions that change the game
4) getting 7 mpg while towing blows
5) we will take the turbo off the diesel when you take out two cylinders (yes, both retarded)
6) the 5.4 is a turd for towing, I don't care what the funk you say!
7) one guy on here has too much time to research funky quotes
8) what ya'll have said is the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent discussion were any of you even close to anything that could be considered a rational thought. Everyone in the forum is now dumber for having read it. I award all ya'll no points and may God have mercy on your souls!!!
9) I like Rush's post better!
Old Aug 4, 2009 | 10:46 PM
  #879
mountaineer27
never said anything about a tuner.
Old Aug 4, 2009 | 10:49 PM
  #880
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by Johnny Langton
So go ahead and pull the turbo off and see what happens when you've got all that smoke pouring out of it. Your theory says it'll still make alot of power without a turbo to add airflow to the equation. Prove me wrong-I'm waiting.
There's a real reason that there are very few to no N/A diesels left out there in on-road vehicles-they're a pig.
JL
Not to mention what you're really doing to the longevity of the motor. Washing the oil off the cylinder walls is never a good thing.
Old Aug 4, 2009 | 10:55 PM
  #881
mountaineer27
Fuel is part of the equation-not the entire source for the power gain.
Pour all that fuel into the engine without adding air via MORE BOOST and see what happens. The same thing happens with force induction on a gasoline engine.
JL
You were wrong the first time and you're still wrong. Wanna go for a perfect three out of three? If you poor a bunch of fuel into a diesel then you get a bunch of power and a whole bunch of smoke. You can make things even better with a properly sized turbocharger, but it is not necessary.
The same thing does NOT happen to gasoline engines. You have to be extremely careful with the fuel-air ratio and that limits the amount of fuel you can inject. I've owned supercharged cars in the past and currently have a supercharged big block Chevy. Running lean is the death of a supercharged engine.
yes you can put more fuel into a diesel and get more power, but only to a certain point. to much fuel and theres not enough air.
Old Aug 4, 2009 | 10:59 PM
  #882
alchymist's Avatar
alchymist
"Mifflin Clay"
Fact's are:
Ouch! Methinks somebody struck a nerve...or two!
Old Aug 4, 2009 | 11:05 PM
  #883
2001400ex's Avatar
2001400ex
haha, not at all!!!! me laughing!!!!
Old Aug 4, 2009 | 11:31 PM
  #884
hughjazz's Avatar
hughjazz
Old Aug 4, 2009 | 11:43 PM
  #885
QwkTrip's Avatar
QwkTrip
Either half of us are right and half of us are wrong, or everybody is wrong. But we can't all be right.
Good bye to the insane and ridiculously long V10 vs. PSD thread of summer 2009. We'll meet again next year, I'm sure.
