Sponsored by: Real Truck
Gas vs PSD
Old Aug 3, 2009 | 08:50 PM
  #826
Tom's Avatar
Tom
I believe the standard figure is a 3% power loss for every thousand feet you go up.
So, at a 11,000 foot pass, such as the Eisenhower tunnel in Colorado, you'd lose 33% of your power.
Been over that pass in my work truck a few times. Believe me, until the turbos spin up, there's almost no power to be had!
Old Aug 3, 2009 | 09:09 PM
  #827
QwkTrip's Avatar
QwkTrip
Originally Posted by KelVarnson
Oh, there's ignorance in this thread alright..... If a properly-geared 300 HP motor does not outpull a properly geared 250 HP motor, someone is lying about their numbers.
Part of the confusion, or ignorance as you call it, is that people are highly focused on peak numbers. Your statement is a good example of that confusion and the 5.4L (~300 Hp) vs. 7.3L (~230 Hp) is the perfect answer to that statement.
Driving a vehicle is dynamic. An engine isn't an on/off switch that goes from idle to peak torque and/or horsepower. You have to drive up through gears and run at all engine speeds. The engine that makes the most average power during the race wins. There is no way in hell that a 300 Hp 5.4L can out tow a stock 7.3L. Hook up a load and the 7.3L makes greater power most of the time, while the 5.4L makes greater power a little bit of the time. The heavier the load the greater the disparity. And don't give me some wild idea that you're going to put 8.xx gears in the rear axle. You want a tow rig not a rock crawler.
Now, if you don't believe me then please explain why a 400 Hp Honda Civic engine isn't a good choice for a heavy truck. We all know it is true... but WHY???
Old Aug 3, 2009 | 09:18 PM
  #828
Johnny Langton's Avatar
Johnny Langton
Originally Posted by 04redstroker
I can make much bigger numbers from my diesel then with a v10. Even if you keep it simple, say just a programmer. A gas engine may be able to get 25 more HP and have to run premium. While a diesel can easily make 100+ more with basic tunning.
You diesel fume boys all ignore the fact that the diesel has a turbo on it. It has a limited amount of boost allowed from the factory, and that big 100+hp tuning number comes from allowing the turbo to force even more boost into the engine. It's not some magical diesel thing that allows it to make more power just because it's a diesel. It's simple...more boost=more dynamic engine displacement=more torque and horsepower.
The V10 does the same job in stock form as the diesel does. It does not use a turbocharger or any other power adder to do so.
JL
Old Aug 3, 2009 | 09:26 PM
  #829
QwkTrip's Avatar
QwkTrip
Wrong. 100 Hp is gained by adding more fuel. It really is a "magical diesel thing".
With a diesel you can make more power by just dumping more and more fuel to it. Any turbo upgrades are so that you can pack in higher density air to burn that fuel and make even more power. Try that on your V10, gassy.
Old Aug 3, 2009 | 09:27 PM
  #830
Tom's Avatar
Tom
True, but I disagree on one point here.
It has so much more to do with how much time can be spent near peak HP for the gasser here. There's nothing to say that the gas motor can't spend the duration of the pull at 5,000 RPMs in 2nd gear, pulling at over 60 mph! In that case, there is NOTHING the 7.3 can do that would come close to it.
All it takes is for the tranny to be able to keep the engine near peak HP. And the 5R110 used in the last few years is remarkably good at doing just that.
Old Aug 3, 2009 | 09:33 PM
  #831
alchymist's Avatar
alchymist
"Mifflin Clay"
not factory, but modded. Just curious. Im talkin if you went all out, say headers, intake, MAFS, exhaust, tuning, and maybe a whipple SC or BBK twins
Almost factory:
590 horsepower at 6,500 rpm and 509 foot-pounds of torque at 5500 rpm
Heres the link, good reading:
http://www.drivingenthusiast.net/sec...m58d/index.htm
Old Aug 3, 2009 | 09:38 PM
  #832
QwkTrip's Avatar
QwkTrip
So your plan is to win the race by holding steady at 60 mph?
Seriously, think about what you're saying. You're going to load up a 5.4L to the point where it can't get past 60 mph. What do you think a 7.3L would do with that same load? Remember that both trucks have to begin from a stop in 1st gear. You know the truth... speak forth the truth!
Old Aug 3, 2009 | 09:51 PM
  #833
hughjazz's Avatar
hughjazz
If the combination of axle gears and transmission gears allows the 5.4 to be at peak rpms In theory it will be faster up a hill.
It's not rocket science.
The diesel is a nicer tow vehicle, because it does the job without as much drama. (5000rpm)
Old Aug 3, 2009 | 09:55 PM
  #834
QwkTrip's Avatar
QwkTrip
You have to get to that speed first. You don't get dropped from a plane onto the road at precisely the correct speed. After all, it's not rocket science.
You also forgot to say at the correct weight.
Old Aug 3, 2009 | 10:15 PM
  #835
Rush117's Avatar
Rush117
I, for one, don't ignore that my diesel has a turbo. The turbo is the REASON I have a diesel. Sometimes I even roll the windows down just to listen to it in all of its glory.
Old Aug 3, 2009 | 10:17 PM
  #836
mudmaker's Avatar
mudmaker
So pulling that pass the 3v V10 would start out with around 300 hp and top out at 240 hp.
(all on paper of course as we have yet to see a dyno sheet on a V10)
Old Aug 3, 2009 | 10:24 PM
  #837
QwkTrip's Avatar
QwkTrip
It has been a very long time since I did any kind of motion problems so I need your help.
If you want to maintain a constant speed up a constant slope then we have a steady state scenario. You will have to apply a constant pushing force equal to the weight of the rig pulling you back down the hill plus the rolling & wind resistance. Correct?
And the pushing force comes from the force created by the wheel torque applied at the road. Correct?
So, the engine that produces the greatest torque wins, right? We all know that is the 7.3L. Did I make a mistake? You're probably going to pull out the 4-speed vs. 5-speed tranny wild card. But I have a 6-speed. Never found a gear that wasn't perfect for any situation.
Old Aug 3, 2009 | 11:04 PM
  #838
QwkTrip's Avatar
QwkTrip
Besides.... Has anybody EVER seen a 5.4L pull anything over a mountain pass at the speed limit?
I didn't think so. End of discussion.
Old Aug 3, 2009 | 11:20 PM
  #839
KelVarnson's Avatar
KelVarnson
Correct.
Sorry, no. The engine that is producing the most power wins (if the gearing is right). Power is basically torque times RPM. As the gears reduce the engine speed, they increase the torque, but the power remains the same. A gas engine doesn't have to be producing more torque than a diesel motor, if the gasser is spinning much faster. After the more significant gear reduction for the gasser, the rear-wheel torque can end up being more.
Again, this is the beauty of using horsepower to compare trucks, because it takes into account both torque and speed. The horsepower at the rear wheels at any given moment is basically the same as the engine horsepower at that moment, minus drivetrain losses.
Old Aug 3, 2009 | 11:33 PM
  #840
hughjazz's Avatar
hughjazz
I have a 6 speed too. (5.4) That was my point though, within a second or 2 I am at my peak hp. 4500 rpm+/-. then I shift from low to first, etc. The Idea of a transmission is to keep the truck at the rpm that works best.
For me it's high.
for diesels it's low.
the tires don't know or care if it's gas or diesel turning the drive train.
or if the engine is revving at 5g, or 2200. The truck accelerates based on the power being applied to the wheels.
hp is hp.
I also did say in theory. Although for the amount of heavy pulling I do, the 5.4 works great for me.
I have owned a few psd's and a 97 12v cummins.
The cummins kicks the crap out of the psd, and the v10 in real world everyday use.
I think for the most part, most will agree the diesel makes the most comfortable beast of burden.
but for some, they don't pull often. and if they do pull heavy, the v10 is more than capable.
