Sponsored by: Real Truck
Gas vs PSD
Old Oct 20, 2010 | 05:51 PM
  #9016
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by exiled
Bill I wasn't being sarcastic. You might have known 601 pgs ago that the v10 would have been dropped. I didn't. I really wanted to know where you go from here. I understand what you mean about buying used. I've only bought myself 1 new truck the rest has been used. My 05 150 was my only brand new truck. The 6.2s we've driven lately is sweet. My wife is gonna get her one before its over with. Anyway I just wondered if a 450 was in your futur.
No, I did not know when the thread started. It was a few weeks after that I started hearing rumors of them dropping it.
Yea, the whole 2011 superduty looks great with either engine.
The only thing that would make me move to bigger truck would be if I got into hotshot, and the work is just not there to do that. I like my SRW truck, its better off road and not a pain to drive in the city. Unless I have to have the payload to take the pin weight of a GN, I plan on staying with SRW F350s.
Originally Posted by tgreening
Then again, so can the diesel. TQ advantage re-acquired.
The V10 can run a gear lower and not over rev. If you try and run your PSD in the same gear as me up a grade, you will dump parts out of the block.
Old Oct 20, 2010 | 05:54 PM
  #9017
bill11012's Avatar
bill11012
Originally Posted by 2001400ex
There is no way the 6.2 will outpull a stock 6.4....
Why is that?
Old Oct 20, 2010 | 06:14 PM
  #9018
driximus's Avatar
driximus
I was looking for a SRW F-350 myself couldnt find one at the time so we went 250.
Old Oct 20, 2010 | 06:15 PM
  #9019
tgreening's Avatar
tgreening
Who says I have to run in the same gear as you? You're the one that has to crank 4500 rpm, not the PSD.
Old Oct 20, 2010 | 06:21 PM
  #9020
Wagion's Avatar
Wagion
Really? This thread is still alive?
Old Oct 20, 2010 | 06:34 PM
  #9021
exiled's Avatar
exiled
I don't understand whatcha mean.
I must be misunderstanding you. Are you saying you can pull the same speed in 3rd as I can in 4th?
Old Oct 20, 2010 | 06:41 PM
  #9022
driximus's Avatar
driximus
Yes it is, If you have not yet, Give Bill some Reps for starting one of the longest documented arguments on the Internet.
Old Oct 20, 2010 | 07:07 PM
  #9023
Lead Head's Avatar
Lead Head
For any given road speed, the diesel will have to be in a higher gear then the V10. The diesel can't drop many gears because if its low rev limit.
Say you hit a hill at 75MPH with a PSD (and 5spd torqshift). Assume 3100 RPM redline, 31" tires and 3:73 rear gears. That diesel will only be able to drop down to 4th. If you're going above 77, it won't be able to downshift at all. A V10 with a 5300 RPM redline and 3.73s will be able to downshift all the way to 3rd (4700 RPM). You could be going as fast as 83 and the V10 will still be able to downshift to 3rd.
For curiosity's sake, lets run some math: 75 MPH road speed with 31" tires:
362 HP V10 @ 4700 RPM = 404 lb-ft. 3rd gear ratio of 1.545:1, 3:73 rear gears = 2328 lb-ft to the wheels.
362 HP V10 @ 4700 RPM = 404 lb-ft. 3rd gear ratio of 1.545:1, 4.10 rear gears = 2559 lb-ft to the wheels (V10 can still pull 3rd gear @ 75MPH with 4.10 gears)
350 HP 6.4 @ 3100 RPM = 600 lb-ft. 4th gear ratio of 1:1, 3.73 rear gears = 2238 lb-ft to the rear wheels.
Look at that, the V10 is able to put more torque to the ground traveling at the same highway speed as a 6.4. Both engines in a gear which puts them right at the peak of their power output. Hmm..
That's exactly what he is saying.
Old Oct 20, 2010 | 07:23 PM
  #9024
Kajtek1's Avatar
Kajtek1
No problem with reps, but I have seen long threads "gasser v/s diesels" on RV forum about 10 years ago.
We are only 900 replies from 10,000. I am going for it. Shall I be ready ... tomorrow??
Old Oct 20, 2010 | 07:27 PM
  #9025
Kajtek1's Avatar
Kajtek1
I didn't check it, but I believe you compared the torque at the rpm giving it a max.
But who drives with one speed and one speed only? In real World gasoline engine with steep curve will drop the torque like crazy going down or up from listed rpm. This is where diesel will beat it senseless with pretty flat torque curve.
Old Oct 20, 2010 | 07:36 PM
  #9026
Lead Head's Avatar
Lead Head
Nope, I already factored that in. I derived my torque numbers from the peak HP RPM.
The V10 has a peak torque of 457 lb-ft, but at its peak 362 HP RPM (4700 RPM), it is only making 404 lb-ft. So I used 404 in my calculations.
I did the same with the 6.4: The 6.4 is rated at 650 lb-ft @ 2000 RPM, but at its peak 350 HP RPM (3000) it is only making 600 lb-ft
Also, the modular series gas engines (and just about every other modern big-displacement gas engine actually) have very broad, very flat torque curves. A V10 generates 90% of its peak 457 lb-ft at just 1200 RPM, and maintains at least 400 lb-ft all the way to 4700 RPM (and probably a bit beyond). These aren't like that 1970-1990s truck V8 gassers that run out of breath and call it quits once they hit 3500 RPM...
Old Oct 20, 2010 | 07:45 PM
  #9027
acf6's Avatar
acf6
Same arguments for 600 pages
Old Oct 20, 2010 | 08:05 PM
  #9028
bill11012's Avatar
bill11012
I will stay with the SRW trucks unless I start towing gooseneck trailers that have a pin weight higher than what my truck can take.
Yes. I have to run higher RPMs to make the same power, and I need the extra gearing to make as much torque at the ground as you.
Old Oct 20, 2010 | 08:50 PM
  #9029
2001400ex's Avatar
2001400ex
Why is that?
How bout this, you keep throwing out the "hp is the only thing that matters, my v10 will outpull your psd as long as it has more horsepower." So I think the onus is on you to prove it, especially since every test we have seen shows the opposite.
Old Oct 20, 2010 | 09:06 PM
  #9030
Tom's Avatar
Tom
It can, will, and has. Come down to the 6.2L forum and look at THIS THREAD.
In short...
Mike(FordMDB)'s 2011 6.2L truck 0-60 towing 11,000 lbs:
Picasa Web Albums - Mike - 2011 6.2L F350
My '08 6.4L towing 11,000 lbs 0-60:
YouTube - video-2010-05-09-15-23-15
Mike's 6.2L beat me by 5 seconds!!!
