Gas vs PSD
Also keep in mind Tom's truck has 5 speeds (Torqshift) and I only have 4 speeds (4R100).
I'll give you tuned since I was running a 5 Star 93 tow tune and headers but it's not in the same territory as the 3V. The tune was really the only "advantage" I had, other then being about 1400 lbs lighter, over Tom's truck. I would say it my truck did well for being 8 year old technology.
Having the extra gear does help off the line. I will give you that. But also, having 1400 lbs less helps a LOT too. In drag racing, every 100 lbs you take off in weight helps you go .1 seconds faster in a 1/4 mile. If you all just pulled for 1/4 of a mile then you would have been 1.4 seconds faster on nothing but weight alone. You all pulled for a mile though, so you had a huge advantage there. Add 1,400 lbs to your trailer to make the gcw even and Tom would have won by quite a bit more.
The 3v makes more peak hp because the heads flow better at higher rpms and it continues making power at 5-6k rpm where the 2v doesn't, but from 1-4k rpm they make the same power. The 3v would have helped, but I don't know if it would have been able to pick up 20 extra mph, especially in that short of a distance. I think your truck did a good job and I repped all of you all for putting the test together, so don't think I am talking bad about truck or anything like that.
To me, the TS wouldn't make a difference since your shootout was based on mph's and not time, but the weight would. The hill leaving my house is is a 15% grade, 1/4 mile long and pulling out from a stop sign mid hill. Same thing as your alls shootout, but shorter. Both of my trucks are manuals and I can reach the same speed by the same points whether I pull out in 1st or 2nd gear, although my time getting there varies. Pulling out in 2nd is a little slower getting started, but once I get rolling it doesn't matter what gear I pulled out in. I just know how much of a difference the weight can make on the mph's because one of the cars I haul weighs about 1,400 lbs more than another one and I can tell you which one is on the trailer without even looking.
I, for one, think the 5-speed tranny would have made a difference. Mike's truck kept accelerating in 2nd gear, but slowly. A shorter first gear would have allowed it to enter a shorter second much sooner and higher in the RPM range, which would have increased the power to the ground in that gear.
JL
Sooner or later I am gonna get in on one of these trailer tugging get to gathers.
These mph numbers aren't exact, but they are close and I need to have something for comparisons sake. If I pull out in 1st(4.14 ratio) and run it to 3k rpm and then shift to 2nd, I am going to be doing 15 mph in 2nd gear at 2,000 rpm once I shift. If I pull out in 2nd(2.37 ratio) it takes me a hair longer time wise to get to 2,000 rpm, but once I get there I am still in 2nd gear doing 15 mph. I have the same speed, in the same gear, turning the same rpm. I have the exact same gear ratios in 2nd-5th no matter which gear I start out in though, so if I can hit 2nd gear it doesn't make a difference how I got there from then on out. I can see it being a difference on a tranny with different ratios in all the gears though.
If the ratios were drastically different then I could see the TS being a huge advantage, but first isn't really that much steeper in the TS(3.09 to 2.71) and the rest of the gears are really close(most are identical, with both having a 1.54, 1.0 and .71). It's like racing a car with a c4 in it and then putting a 2 speed powerglide in it. The c4 is a lot quicker off the line, but by a little past the 1/8 mile mark both have a 1.0 tranny ratio and both cross the 1/4 mile line at the same mph.
Look at it this way too. You had a .38 advantage in gearing off the line. That is the same difference between a 4.10 and 3.73(.37 to be exact). If you put a 4.10 gear in your truck and then put 1,400 lbs in the bed, do you think it would still out run your empty truck with a 3.73? Not saying you didn't have an advantage gearing wise, but I just don't think it was enough to offset the weight differential.
500 pounds of the weight is the V10.
Is the other 900 just the 05-10 vs 99-04? Did they really beef it up that much in 05?
I live at the bottom of a valley and about all the roads getting out of my neighborhood are 15-25% grades, 1/4 mile long and from a dead stop, so I get to test my theory every single day lol.
YouTube - My Turbo V10 Excursion doing a Big smokey burnout.
This guy used to be a member, he talked about selling it and then just left FTE.
He put a turbo on it and burned it all way up to third gear.
Please take note of the fact all 10 spark plugs stayed in.
