This guy used to be a member, he talked about selling it and then just left FTE.
He put a turbo on it and burned it all way up to third gear.
Please take note of the fact all 10 spark plugs stayed in.
LOL didnt see this one thanks.
Originally Posted by mountaineer27
[IMG]www.youtube.com/watch?v=4hf46Jbdxvo[/IMG]
Originally Posted by bill11012
He never got out of first.
The Ex ran all the way up to the 1 to 1.
If a N/A V10 will beat a Power stroke, than how much will a turbo V10 beat a power stroke by?
I have never seen a video of one at the track or pulling a sled. But that was pretty sweet. Ill take a N/A or turbo'd one on im not picky. If I run a Turbo'd V-10 just to keep everything fair we have to Launch at 25 Lbs of boost!
I would have to build the motor up , but it could be made to do it.
I have seen a 4.6 ( same thing, just lower deck height and 2 less cylinders) running 30 PSI off twin turbos.
It made 1300 HP.
After reading the 'test' the guys did a while ago, was the 4wd launch needed?
With all that weight on the trailer (and on the tongue), I don't think the truck would have done a burn out as much as just lifting a front tire or two off of the ground.
It's not just the 4x4 at least for the diesels it just helps keep traction when used in comination with doing a boosted launch.
I don't even know what to say after that mental image.
Is there a pic?
I finally got some time to look through my old pics. Keep in mind this is the first car I ever built and I was only about 6 when I did it. Dad was going to junk the car, but I asked him if he would show me how to do some body work on it, and this is the end result. And yes, I designed the paint scheme (it shows, and is a good reason not to let a kid pick out paint lol).
