Gas vs PSD
What is Horsepower?
Don't believe me?
Do a dyno pull with no RPM input and see what gets printed on the sheet and what's missing.
JL
Don't believe me?
JL
wiki- Dynamometer - Wikipedia, the free encyclopedia
A dynamometer or "dyno" for short, is a device for measuring force, moment of force (torque), or power. For example, the power produced by an engine, motor or other rotating prime mover can be calculated by simultaneously measuring torque and rotational speed (rpm).
also
How Does a Dyno Work? | eHow.com
What is Horsepower?
No modern dyno measures torque either. All modern dynos measure power and then derive torque through calculations. The three most common dynos are:
1. Inertia Dyno. accelerating a heavy drum, where a computer measures how fast the drum was accelerated(the power that was put to the drum) and based on an RPM trigger sensor placed somewhere on the engine, the dyno's computer can figure out how much torque the engine put out.
2. Electrical dyno. The wheels (or engine crankshaft) essentially spin an electrical generator which is connected to an electronic load bank. It measures exactly how much power is generated, and once again using a crank sensor it calculates the torque by how much power was generated at a specific RPM.
3. Hydraulic dyno. An engine is loaded up into a hydraulic motor, either pumping hydraulic fluid or water, and some kind of restriction is put in line with the output. A computer measures how much fluid the engine can force through the orifice at a given pressure and then calculates the power being produced. Want to take a guess on how it calculates torque? You guessed it, a sensor measures the RPM and it calculates the torque from the power.
The only type of dyno that I'm aware of that measures torque (and NOT power) is the de Prony brake, and whens the last time you you hooked your truck upto one of those?
Here is some basics on how they work. Pay close attention to the part how they actually com-bust the fuel they inject.
HowStuffWorks "How Diesel Engines Work"
also
Dynos measure horsepower-period.
JL
But besides that Johnny Langton is correct, a dyno should not care whether or not its a diesel or a gas engine. Any settings that a dyno operator is changing are just trying to give people an estimation on horsepower being produced at the crank.
The reason big rig engines have such high torque, is because the engines spin so slow. Topping out at ~2000 RPM. The slow spinning engine is a necessity for long hauling. It helps conserve fuel, and it means the engine will last longer since its spinning so slow.
Here this diesel spins at 102 RPMS, However its the most powerful one in the world. The Most Powerful Diesel Engine in the World
HowStuffWorks "Why do big diesel engines and race car engines have such differe"
"Let's start by answering the question and then look at why the world works that way. The answer to your question has to do with the way the two engines are designed. Your 11 liter diesel engine has a long stroke. That means that the piston is traveling a relatively long distance up and down in its cylinder on each cycle. A racing engine, on the other hand, has a short stroke. The piston in a racing engine has a large diameter for the engine size, and it goes up and down a relatively short distance on each cycle. This means that a race car engine can run much faster -- up to 15,000 RPM in a Champ Car engine -- but has relatively little torque. A large diesel engine usually cannot get above 2,000 RPM, but has huge torque because of the long stroke. The torque is what lets your engine pull a huge load up a hill."
Once again torque moves stuff not Horsepower.
If you put that 362HP V10 into that same big rig that had that 330HP 1400 lb-ft diesel, and gearing in it so that the engine spins ~4500 RPM in the highest gear at 65-70MPH; it will out pull that giant diesel. Will the V10 last long spinning 4500 RPM at WOT day and day out? Probably not, but it will still output that lower HP diesel. In fact, if you had a little 350HP Turbo V6 or 4 Cylinder and geared it so it spun 6000-7000 RPM at 65MPH in top gear, it would output that big diesel too.
JL
if i'm wrong about the dyno then so be it. But considering Engines all of them Make Torque and then Horsepower is based on how fast that torque is being done. I will still go with Dynos measure Torque and the rate at which that work is done is how they get that Horsepower. Read the article I posted above, If you still refuse to believe how engines make Torque and that Horsepower is only how fast the work is done not how much work it can do. Then so be it.
Many years before Mercedes Benz was producing engines with over 450 horsepower, a man named James Watt made some observations, and concluded that an average horse could lift a 550 pound weight one foot in one second, thereby performing work at the rate of 550 foot pounds per second, or 33,000 foot pounds per minute, for an eight hour shift, more or less. Watt published those observations, and stated that 33,000 foot pounds per minute of work was equivalent to the power of one horse, or, to cite on of our topic of the day, one horsepower.
To further explain, let us look at the following scenario. If you have a one pound weight bolted to the floor, and try to lift it with one pound of force (or 10, or 50 pounds), you will have applied force and exerted energy, but no work will have been done (hence, you have zero horsepower.) If you unbolt the weight, and apply a force sufficient to lift the weight one foot, then one foot pound of work will have been done. If that event takes a minute to accomplish, then you will be doing work at the rate of one foot pound per minute. If it takes one second to accomplish the task, then work will be done at the rate of 60 foot pounds per minute, and so on.
Torque Definition: The measure of the force applied to an object to produce rotational motion, usually measured in foot-pounds.
Torque literally refers to the turning or twisting force of an engine An engine may be very powerful, but if it has little torque then that power may only be available over a very high and limited rev range, making it of limited use to the driver. An engine with more torque - even if it has less power – often proves to be much quicker on the track, as the power is available over a far wider rev range and hence more accessible.
To give a slightly more technical explanation, one foot pound of torque is the twisting force necessary to support a one pound weight on a weightless horizontal bar, one foot from the fulcrum.
Imagine, if you will, this one pound weight, one foot from the fulcrum on its weightless bar. If we rotate that weight for one full revolution against a one pound resistance, we have moved it a total of 6.2832 feet (Pi * a two foot circle), and, incidentally, we have done 6.2832 foot pounds of work.
Now, it’s important to understand that nobody on the planet ever actually measures horsepower from a running engine. What we actually measure (on a dynamometer) is torque, expressed in foot pounds (in the U.S.), and then we *calculate* actual horsepower by converting the twisting force of torque into the work units of horsepower.
OK. Remember Watt? He said that 33,000 foot pounds of work per minute was equivalent to one horsepower. If we divide the 6.2832 foot pounds of work we’ve done per revolution of that weight into 33,000 foot pounds, we come up with the fact that one foot pound of torque at 5252 rpm is equal to 33,000 foot pounds per minute of work, and is the equivalent of one horsepower. If we only move that weight at the rate of 2626 rpm, it’s the equivalent of 1/2 horsepower (16,500 foot pounds per minute), and so on. Therefore, the following formula applies for calculating horsepower from a torque measurement:
Horsepower =
Torque*RPM
5252
so an Engine produces Torque/work and if Horsepower is a measurement of how fast that work is being accomplished.
Ergo,
An Dyno measures torque of a vehicle and calculates Horsepower based on the speed of the engine.
Once again, you're wrong. I can apply torque to something, but it needs to be rotating torque to actually move something. The moment I start to rotate that force, it becomes power. Power is what lets those big diesels pull a huge load. They have lots of low end torque, so they can still generate useable power at low RPMs. Once again, spinning at low RPMs maximizes engine life and fuel economy. More power down low also makes it more pleasant to tow as you may not have to downshift as much, But ultimately its the power the engine is putting out that is moving that load.
<!-- END TEMPLATE: bbcode_quote -->
And once again, most dynos measure power, not torque. Here is a picture from wikipedia that shows it well:
This is an electrical dyno. It generates electricity which gets measured in watts (watts is power, 746 Watts = 1HP) This shows how much HP the engine generates. This type of dyno cannot measure torque directly. So, it needs that torque arm + scale (4,5 on the picture). The generator housing is free to rotate on the trunnions, the torque arm is attached to the housing and the other end of the scale is attached to something solid. As the dyno operator loads up the engine with the generator, the scale measures how much the generator housing twists/pulls against it. This is the engine's torque reading. So it needs this scale/arm to measure torque. You could figure the torque based on engine RPMs and how much power its generating, but it won't be as accurate.
<!-- END TEMPLATE: bbcode_quote -->Yes, I know that. But with that stupidly low gearing, it would have more pulling ability with the same top speed as that Diesel. That proves that when it comes down to it, power is what moves loads.
On modern day dynamometers horsepower is a calculated value. It's important to remember the dyno measures torque and rpm and then from these calculates horsepower. On the dyno it takes more water flow to the water brake to increase the load on the engine being tested. As the test engine's torque rises more water flow is needed. As the test engine's torque drops less water flow is needed. The dyno's water brake does not respond to Horsepower. Major adjustments to water flow are needed as an engine crosses its torque peak but none are needed as it crosses its horsepower peak. In other words the water flow to the brake during a dyno test follows the engines torque curve and not its horsepower curve. Torque is what twists the tire, prop, or pump. Horsepower helps us understand an amount or quantity of torque. (Torque + time and distance)
