Sponsored by: Real Truck
Gas vs PSD
Old Dec 12, 2009 | 03:58 PM
  #2971
phillips91's Avatar
phillips91
Originally Posted by Sand_Man
I hate to inject some truck talk here, but how accurate is everyone's fuel gage? I know my truck (SB) has a 29 gallon tank, but when I filled up today, it had just over 1/4 showing on the gauge, yet 14 gallons (less than 1/2 tank) brought it up to full. Is everyone's about the same or have you noticed?
On my super duty when my gauge hits E and my low fuel light comes on I still have 8 gallons in a 39 gallon tank. My OBS doesn't have a low fuel light, but I have driven 80 miles with it on E before just to see when it would run out and it still didn't. That was on the 21 gallon side of the dual tanks. So that is at least 4 gallons worth of fuel still in the tank when it hits E. Just a guess, but it may be to keep people from running out of gas because they are too busy talking on phones, etc, to pay attention to their gauges.
Old Dec 12, 2009 | 06:09 PM
  #2972
95_Dually's Avatar
95_Dually
I don't have a mom, me and my dad share yours.
Old Dec 12, 2009 | 07:43 PM
  #2973
bill11012's Avatar
bill11012
Modular motor junkie
Haha, nice one!
Old Dec 12, 2009 | 08:31 PM
  #2974
95_Dually's Avatar
95_Dually
Bill, this has gotten WAY OFF TOPIC! Are we finally exhausting the V-10 can outpull the PSD arguement. Maybe the gassers have finally ran out of fuel and now gas is on back order.LOL
Old Dec 12, 2009 | 08:49 PM
  #2975
Old93junk's Avatar
Old93junk
How about, "Briggs and Stratton vs. Tecumseh"........."My Briggs will out mow your Tecumseh any day of the week".........I think this thread has about run its course.
Old Dec 12, 2009 | 09:07 PM
  #2976
bill11012's Avatar
bill11012
I have no clue why it is on the current topic.
I have done what I wanted to do, which was find out more of the PSDs high points. I also learned many other things about both the V10 and PSD.
I still say that the PSD is inferior to the V10 in a lot of ways.
One question that I never heard an answer to:
Which can Idle better for a long amount of time?
Old Dec 12, 2009 | 09:36 PM
  #2977
phillips91's Avatar
phillips91
It can't run its course until we hit 200 pages. A couple more post and that should get us there.
Old Dec 12, 2009 | 09:42 PM
  #2978
PorchFarms's Avatar
PorchFarms
Well bill if you are asking about the 7.3 you can idle that motor as long as you want with no problems. My old 7.3 one time my starter was on the way out i should have replaced it by then it had 189000 miles on it but anyway i got under it and hit the starter with a hammer and got it started and left it idling for 3 days till i got a new one. My wife was mad because at night i parked it under the car port and you could hear it all night. Now the 6.0 and the 6.4 you can idle them just not as long unless you put the high idle mod on. My 6 liter has idled all night before with no problems. Ford is fixing the problem of idling by moving the egr valve to the hot side of the cooler in the 6.7. Now to ask you a question if a gas burner is so great at idling and pulling heavy loads why do semi trucks use diesels. And why does construction and farm equipment use diesel engines.
Old Dec 12, 2009 | 09:43 PM
  #2979
phillips91's Avatar
phillips91
Originally Posted by bill11012
One question that never got heard an answer to:
As long as you have a properly functioning cooling system either of them should be able to idle however long you want them too with no immediate problems. We have gassers and diesels on our job sites that idle for 10-12 hours at a time. However, the gassers usually start showing major signs of wear around 125-150k miles and get traded in. Several of the diesels have 400-500k miles on them and are still running strong.
Old Dec 12, 2009 | 10:11 PM
  #2980
bill11012's Avatar
bill11012
Crap, I need to re-read before I post .
What has major wear? Any one thing or or is it burning oil, low compression, etc.?
What kind of gassers?
Old Dec 12, 2009 | 10:24 PM
  #2981
bill11012's Avatar
bill11012
For HD, diesel is the only choice for a whole list of reasons.
We are talking about light duty, the heaviest a V10 is rated for is 33,000.
Same with the PSD.
Old Dec 12, 2009 | 10:40 PM
  #2982
PorchFarms's Avatar
PorchFarms
33000 pounds is getting you in cdl territory. The powerstroke is used along with the v 10 in medium duty trucks also. We can argue the different points all night long. I have been around the psd, v10, 5.4, 460, 5.9 cummins, all the gm motors from the diesel to gas, all farm equipment. The ford engines have always been the best. I had better luck out of my psd than the v10. The gas burner blew part of the head off under 20000 miles so i traded it for another powerstroke and will never look back. Just my opinion.
Old Dec 12, 2009 | 11:00 PM
  #2983
95_Dually's Avatar
95_Dually
Bill, why is idling important to you? The PSD won't need to change spark plugs or replace coil packs, EVER. Therefore the PSD will idle longer.LOL
Old Dec 12, 2009 | 11:07 PM
  #2984
bill11012's Avatar
bill11012
Yes, they are both used in the F550 with a 33,000 pound GCWR.
We can argue the different points all night long. I have been around the psd, v10, 5.4, 460, The ford engines have always been the best.
I have been around a dodge gasser,
A few Chevy gassers and all the ford motors you listed.
The fords are better no matter what motor you go with, we can both agree on that.
I just happen to have a V10 that Is by far the best motor of anything I have ever driven. If you feel the same way about a PSD then I know just how you feel.
If you had a V10 that did that I can see why you would go with a PSD to replace it. Did it blow a plug?
  #2985
phillips91's Avatar
phillips91
Exactly what you listed here. Burning oil, low compression, vibrations, etc. Probably 90% of the gassers are 5.4's and v10's. Very few of them carry any kind of load at all though. They are just company trucks that are left idling to keep the guy driving it warm. We have several people that their only job is to sit in their truck and watch other people work, so they sit there idling for the day. Most of the others are just tag along pick ups that follow the bigger truck that is there to do work.
