Sponsored by: Real Truck
Gas vs PSD
Old Dec 12, 2009 | 11:12 PM
  #2986
95_Dually's Avatar
95_Dually
Josh, that sounds like a very boring job. Sitting in your truck watching others work. I would go crazy doing that.LOL
Old Dec 12, 2009 | 11:19 PM
  #2987
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by 95_Dually
Bill, why is idling important to you?
It was just one thing that never came up during the whole thread.
I Idle it as much as 4 hours some days using the a/c,heater,Headlights and running the winch.
The PSD won't need to change spark plugs or replace coil packs, EVER. Therefore the PSD will idle longer.LOL
Tell you what, I'll take my spark plugs out.
You take your glow plugs out.
Then we will see which truck will outpull the other and settle this once and for all.
Old Dec 12, 2009 | 11:22 PM
  #2988
95_Dually's Avatar
95_Dually
I do not need glow plugs. I can plug the holes and my truck will still start and run. Yours will not run.
Old Dec 12, 2009 | 11:25 PM
  #2989
95_Dually's Avatar
95_Dually
So I guess you will agree since yours will not run the PSD is the better truck.
Old Dec 12, 2009 | 11:29 PM
  #2990
bill11012's Avatar
bill11012
Originally Posted by phillips91
Exactly what you listed here. Burning oil, low compression, vibrations, etc. Probably 90% of the gassers are 5.4's and v10's. Very few of them carry any kind of load at all though. They are just company trucks that are left idling to keep the guy driving it warm. We have several people that their only job is to sit in their truck and watch other people work, so they sit there idling for the day. Most of the others are just tag along pick ups that follow the bigger truck that is there to do work.
You had 5.4s and V10s dieing at 125K?
There are ones that have over 1,000,000 miles on them.
Is idling them much worse then normal driving?
Old Dec 12, 2009 | 11:38 PM
  #2991
bill11012's Avatar
bill11012
Wow, that line of thinking blew up in my face.
I did not mean you could plug the holes.
Old Dec 12, 2009 | 11:42 PM
  #2992
95_Dually's Avatar
95_Dually
That was a gimme. Thanks Bill.
Old Dec 12, 2009 | 11:45 PM
  #2993
95_Dually's Avatar
95_Dually
I will let you plug your holes too. You can use your spark plugs. Just leave the coil packs disconnected. See, I am trying to help ya out.
Old Dec 12, 2009 | 11:49 PM
  #2994
bill11012's Avatar
bill11012
I should have thought about this BEFORE posting that challenge.
Old Dec 12, 2009 | 11:54 PM
  #2995
95_Dually's Avatar
95_Dually
It ok Bill. I am having fun with this. It is better than the mama jokes. Of course I know a few more but they are the side of cruel.LOL
Old Dec 13, 2009 | 12:05 AM
  #2996
bill11012's Avatar
bill11012
I'm having fun with this too.
I know a lot more your momma jokes, but they are extremely crude.
Old Dec 13, 2009 | 11:28 AM
  #2997
phillips91's Avatar
phillips91
Idling is a little worse than normal driving, but unless it's excessive idling(like on our job sites) it shouldn't cause any harm. What does make a difference is that it's miles don't show up on the odometer. That's why most industrial engines that do a lot of idling(tractors, etc) go by hours instead of miles. For every two minutes you idle it's the equivalent of driving one mile. So if you idle for 8 hours that is the equivalent of 240 miles. Those 5.4's and v10's that were dying with 125k miles on them probably had the equivalent of about 250-300k. Edit-Just did a little research and from what I found, idling is worse on a gasser than a diesel. At idle the fuel in a gasser isn't fully combusted, leaving build up on the spark plugs and cylinder walls, which leads to premature cylinder wear, oil consumption and loss of compression. Diesels don't rely on a spark to combust the fuel, so that isn't a problem for them.
I know of that one million mile van that everyone references when talking about the modular durability, but to be honest with you, I question whether it has that kind of miles on it. Based on the year of the van, the number of miles he puts on it per year, etc, he would have to drive about 300 miles a day(5 hours a day), 7 days a week, 365 days per year in order to get to the miles he is at. That is assuming he never gets stopped by a redlight, stops to eat lunch or go to the bathroom, never gets stuck in traffic, etc. It's possible, but if it's true then that guy has done nothing but drive every day for 12 or 13 years.
Old Dec 13, 2009 | 11:58 AM
  #2998
Tom's Avatar
Tom
You have a good point. But do you understand what he does with this van? He is an O/O for an expediting outfit. His job is very similar to my job as an OTR truck driver; he drives long distances all day, every day. Expeditors very frequently run 5-600 mile days, and because it's not a CDL-class vehicle I don't think he's bound by the federal hours of service, meaning he could really drive far more than that in a day.
Expeditors spend their life on the freeway, not in and around urban areas.
Old Dec 13, 2009 | 12:55 PM
  #2999
phillips91's Avatar
phillips91
Those miles and hours I figured up were based on him driving 7 days a week, 365 days a year for 12 years straight(275 miles per day). Subtract at least 2 weeks per year for vacation time and his miles per day goes up to 285 per day. Assume he gets weekends off and his mileage is up to 400 per day. I may be wrong, but I was under the impression that the HOS applied to any vehicle that has a DOT number(his does). I'm not saying he didn't do it, just that I question it.
Old Dec 13, 2009 | 01:01 PM
  #3000
Tom's Avatar
Tom
My '06 KW that I recently turned in had 555,000 miles on it. It was manufactured in 6/2005 and was NOT a team truck.
Which is harder to believe, 1,000,000 miles in 11 years or 555,000 miles in 4 1/2 years?
Not saying that I know it's true, just that it's very possible.
